Author Topic: anyone replace a blend door actuator in a 05 Suburban?  (Read 26414 times)
Offline MOPAR FANATIC
Re: anyone replace a blend door actuator in a 05 Suburban?
« Reply #15 on: January 23, 2012 - 03:35:08 PM »
 :thumbsup:
OK brad,you have the option of CJ2 A/C HEATsystem [a/c frt auto/aux control]
it takes three of the same part no. actuators which fit the upper center valve flap..the lower center valve flap and the left outer center flap.
the PART NO. on these three is 89018365 temp mode actuators.price is $263.56 retail i would sell one to you for $151.55 {my cost}
you would have to pay shipping from minnesota to canada.if and when if you need one let me know.............
the other actuator that mounts on the right outer center is part no.89018374 mode control actuator.$79.86 retail $45.92 my cost
and sorry brad more than likely you need the more expensive one.this is the one with the high fail rate..........  :(
if you need a parts illustration and service info post or pm me a fax no.i can send them too.  :thumbsup:
Dave.............
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
« Reply #16 on: January 23, 2012 - 05:40:21 PM »
:thumbsup:
Dave.............
Hey thanks! How do I figure what one I need?  Wait till it fails again I guess?
I don't have a fax?
  What have you run across that screws up with the rear heater? I read on the net something about some
do-hicky on the right side rear wheel well that is most likley the cause?
Sure wish they would have left the old tried and true cables and levers that never screwed up for the life of the vehicle instead of all this electronic junk? It's just a heater.... not the space shuttle! LOL
« Reply #17 on: January 24, 2012 - 12:30:08 PM »
 :thinkerg: Brad,the rear module you may be talking about is called a aux htr & a/c control module mounted on the rear hvac unit.part no.15832319 module.retails for $140.06 your cost $75.00.
i could fax you pic's to your wifes workplace if and when you need them.  :thumbsup:
 :cheers:
Dave.....................
« Reply #18 on: January 24, 2012 - 03:20:43 PM »
 :cheers:
Thanks a ton Dave! :2thumbs:  What does this rear controler do? Like is is an electronic motor that allows air/heat to flow or is it a circuit borad brain type thing? Just wondering how to tell if it's gone bad. I don't want to be guessing, replacing parts?
Thanks Brad
Offline wulf011976
  • Newbie
« Reply #19 on: April 11, 2013 - 04:01:24 PM »
I am not getting any air to my defroster on my 2005 suburban?  Blow through the dash only?  Thoughts?
« Reply #20 on: April 11, 2013 - 04:39:21 PM »
Sounds like the electronic controller or one of those actuators?  Mine turned out to be low coolant level I think it was? That was a year ago....short memory!  :grinyes:
Since then the wife "fixed" the problem anyhow! ::) :grinyes:
Offline dutch
« Reply #21 on: April 11, 2013 - 05:08:55 PM »
that`s a pretty good looking headlight you`ve got there....  :biggrin:
how`s your wife doing?
*** Bart ***
« Reply #22 on: April 11, 2013 - 05:11:14 PM »
Pretty good thanks :wave: She says back to 100% :dunno:
« Reply #23 on: April 11, 2013 - 06:14:14 PM »
:thinkerg: Blend mode door actuator probably failed,c-above post for part # and price.more than likely has the same system in it as brads.
to be sure you could post the last eight digits of your vin and i can check it out.  :thumbsup:
Offline dutch
« Reply #24 on: April 12, 2013 - 12:15:48 AM »
thats great  :2thumbs:
*** Bart ***
Offline ckrspan5
  • Newbie
« Reply #25 on: July 17, 2013 - 12:21:46 PM »
I am having a blend door issue on a 2006 gmc 2500 duramax. I came accross this site by google. If possible could ask mopar fanatic to please pm me
Thanks
