Author Topic: OEM Rear Sway Bar End Link Length  (Read 2548 times)
Offline PlumCraZRT
« on: January 25, 2012 - 02:19:28 AM »
Can anyone give me the length of the OEM (or Firm Feel) end link?  I just got my hands on an OEM rear sway bar that is missing some components.
More specifically, can you provide me with dimension "A" in the attached image?
Thank you,
Evan
mmmmm.... Mopar.... *drool*
Re: OEM Rear Sway Bar End Link Length
« Reply #1 on: January 25, 2012 - 08:06:06 AM »
Rear link center measures 3"
FYI front measures 1 3/4"
Offline PlumCraZRT
« Reply #2 on: January 25, 2012 - 11:40:59 AM »
Great!  Thank you!
So you're saying "A" is 3 inches, making the center-to-center distance (from sway bar to mount pad) about 4" or so?
Thanks,
Evan
« Reply #3 on: January 25, 2012 - 12:02:43 PM »
Are you trying to be as correct as possible or don't you care about looking factory correct?  The rear end links weren't just a bolt with a spacer like the front.  It was accually a stud with threads on both ends.  New rear end link kits are available but they are spendy at around $55.  A bolt/spacer will work just fine...it just won't look stock.
Offline PlumCraZRT
« Reply #4 on: January 25, 2012 - 12:42:54 PM »
I would love to have the factory correct setup, but I also realize those kits are $$$ which is why I plan on just getting the Energy Suspension end links.  I was unsure which length I should get...
Thanks!
« Reply #5 on: January 25, 2012 - 03:20:21 PM »
Great!  Thank you!
Thanks,
Evan
Yep
Offline PlumCraZRT
« Reply #6 on: January 25, 2012 - 04:34:59 PM »
Offline Katfish
  • 70 Challenger
« Reply #7 on: January 25, 2012 - 06:21:03 PM »
For a lot cheaper, you can use the FRONT sway bar link from 69 B-body for REAR E-body sway bar link.
MOOG Part # K8266
« Last Edit: January 25, 2012 - 06:28:29 PM by Katfish »
Offline PlumCraZRT
« Reply #8 on: January 25, 2012 - 06:36:15 PM »
MOOG Part # K8266
Thanks for the tip.  Any idea how long the spacer in that guy is?
Offline Katfish
  • 70 Challenger
« Reply #9 on: January 25, 2012 - 06:41:27 PM »
Offline PlumCraZRT
« Reply #10 on: January 25, 2012 - 06:44:05 PM »
~2 7/8" or so.  Sweet!  Thanks again for the heads-up!
Offline PlumCraZRT
« Reply #11 on: January 26, 2012 - 01:45:11 PM »
It's a bit off-topic, but anyone have an alternative part number to the Energy Suspension 3/4" greasable sway bar bushings?  I've attached a pic for reference.
