Author Topic: How to size a sway bar  (Read 555 times)
Offline ff6849
« on: January 25, 2012 - 05:56:08 PM »
What determines what size sway bar one should use?  :dunno:
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline Road_Runner
Re: How to size a sway bar
« Reply #1 on: January 25, 2012 - 06:41:09 PM »
The short answer is a lot things!  But to be more helpful, its really a balance of all your suspension components and how they work together.  If you're staying with stock torsion bars & rear springs, then you likely don't want to go to the largest sway bars available, if you're beefing up your cars springs you'll likely want to go to larger sway bars to match.  Stock these cars that came with 7/8" sway bars on front (believe R/T cars came with heavier 1" front bars?) and 3/4" on back.  So that would probably be a good starting point.  Most of what I have read says that these cars need larger bars with better springs and radial tires so most folks run front bars 1 - 1.25" on front and either 3/4 or 7/8" on back.  Some rear sway bars are adjustable so you can put them on and change the bar mounting holes to where you like the way the car handles.  For my 73 small block Barracuda, I'm going to be installing .96 T bars and heavier rear springs (haven't decided yet) along with better shocks (either Edelbrocks or Bilsteins), a stock 3/4" rear sway bar and either a stock 7/8" front sway bar or a 1 1/8" Hellwig bar.  So the answer is it depends on what else you're changing suspension-wise.  I didn't even mention tires which bigger wider more grippy tires will also be part of the mix.
Later, Jim
« Last Edit: January 25, 2012 - 06:42:46 PM by Road_Runner »
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #2 on: January 28, 2012 - 06:50:35 PM »
And, when talking "bars" remember that the aftermarket ones can be had as tubes as well.  When talking tubular the diameter has to go up for the same amount of control.  PK
The Brewmaster
