Author Topic: The next step. Need some wisdom  (Read 2315 times)
Offline NCtrueconservative
« on: January 25, 2012 - 10:16:10 PM »
Well guys its been a mild winter so far in the mountains of NC and after christmas and not focusing on the chally for a while, I'm itchin to get back at it.  I have quite a few tidying up things that need to be done before I get to drive it (hopefully) for the first time this spring. I was wondering for those of you who have completed projects before, in what order should I do these things?  What should I focus on first? Sometimes I just need direction because all I see is a lot of crap that needs to be done :feedback: And along with direction, I'll prob need some help on the best way to complete the tasks as well (73 challenger rallye, automatic)
-the back tail lights, parking lights, and reverse lights need to be troubleshot and got working
-carpet needs to be installed
-some of the gauges in the dash need to be looked at, which I really don't know much about. My oil gauge is working, and maybe my water I can't remember but I KNOW my speedo and tach are not working
-the passenger side glass needs to be installed along with the regulator mechanism back in the door
I'm sure I'll think of something else later, but those are the big things right now....what to focus on first? hmmm. Thanks in advance
1973 Dodge Challenger Rallye (pictured), 340, Slap Stick
1998 Dodge Ram, 5.2, Black, tinted windows, dual exhaust, blackout headlights, tailights
Offline Killer_Mopar
Re: The next step. Need some wisdom
« Reply #1 on: January 25, 2012 - 10:24:48 PM »
I always found it best to first concentrate on whatever gets the car running or driving and is affordable - once you start making progress and can hear/drive it, the rest of the stuff will come soon after. With that said, my vote is to fix the tail lights - it shouldn't be too difficult, should be relatively cheap, and its something that needs to be done before driving. After that, the dash and window. The window will be relatively quick and easy. The dash will require a little planning, most likely a bit of cash, and a good amount of time compared to the others.  That's just my :2cents:
Offline 67vertman
  • Member since 9-23-2005
« Reply #2 on: January 25, 2012 - 11:19:11 PM »
I agree with Killer, get it running first.  That way you can enjoy it while you drive it.  Then start with the next thing you can afford to do, such as body work, tires, suspension, and such.
Most people who tear thier cars completly apart never finish them, as they lose intrest.
Offline BS CUDA
« Reply #3 on: January 25, 2012 - 11:22:17 PM »
Agreed - I save all winter for the next set of upgrades etc. From spring to fall I drive it every chance I get including hammering it at the track. Wouldn't do it any other way. Someday I will heat the garage so that it sees less downtime in the spring  :jumping: :crazy: :swaying:
Offline Jesus H Chrysler
« Reply #4 on: January 26, 2012 - 09:24:26 AM »
I got a new taillight harness for around $150 this past year at Carlisle.  I used to do auto electric for a living and it was still easier and cheaper to get a premade harness.  It was plug and play, I had it working in under a half hour.  I second the notion of getting it running first.  Once it's running, you become far more motivated to work on it because it's so close.  My car sat for years because it was a hopeless case.  Not running, missing parts and needing soooo much work.  Just putting an engine and tranny in it fired me up to work on it.
The speedo can probably be fixed with just a new speedo cable, or even just peek under the car and see if it's connected.  The other gauges require a little more troubleshooting.  The glass can be put in by copying the other side that is still in.  Breaking the project down into manageable segments is the key to success.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline Jamiez
  • Retro
« Reply #5 on: January 26, 2012 - 09:56:07 AM »
I picked up a used rear wiring harness off moparts for around $50.  I see them from time to time.  It takes around an hour to swap with most of that time being spent threading the wires and dealing with the fuel tank wire.  You should be able to complete it in an afternoon, easily.
To swap the carpet is a lot more work than you might think.  You have to remove pretty much all of the interior to do it correctly.  That means the front seats, rear seat, console, sill panels, kick panels, rear quarters.  Make sure you bag and tag the screws.  Laying the carpet is pretty simple but taking everything out and putting it back together is pretty time consuming...especially if you've never done it before.
For the temp gauge, it's possible that a previous owner removed the thermostat.  It's not uncommon, unfortunately to check you'd need to drain the coolant.  It's not difficult or time consuming, but it's something you should consider while planning these things.
« Reply #6 on: January 26, 2012 - 03:52:47 PM »
really appreciate all the help guys....guess I'll get my taillights working first....and I already have all the interior and old carpet stripped (thank God!!). had to do some floor pan work. And I second that about getting a heated garage  :grinno: maybe one day
Offline Gumby
« Reply #7 on: January 26, 2012 - 08:12:32 PM »
Good luck! I have a heated garage - in the summer! lol. There are lot's of things I want to do, and even have many of the parts, but I'm allergic to cold. lol.
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
Offline BS CUDA
« Reply #8 on: January 26, 2012 - 08:45:00 PM »
Probably best I don't have a heated garage - might have to sell the wife and kits to finance another 6 months of upgrades.   :angelwings: :naughty: :smokin: :cheers:
