Author Topic: Gear ratios  (Read 1059 times)
Offline Fern
Gear ratios
« on: January 26, 2012 - 04:00:36 PM »
Hi,
The rear axle that came in my car had spun a bearing at some point and someone fixed it by placing a metal sleve, needless to say its junk. Since I need a new rear, I was going to go with 355 sure grip, but I have found one thats a 323.
My question is is there much difference from one to the other?  I am looking for something I can drive in town and on the highway, but dont want it to be sluggish from takeoff.
I have 70 challenger with 440 4 speed.
Thanks,
Offline dutch
Re: Gear ratios
« Reply #1 on: January 26, 2012 - 04:43:29 PM »
I don`t think you will have sluggish take off with either one... with a 440 -4 sp.   :bigshades: :burnout:
this may help visualizing things...
http://vexer.com/automotive-tools/speed-rpm-calculator
*** Bart ***
Offline Jocigar
Re: Gear ratios
« Reply #2 on: January 26, 2012 - 05:07:25 PM »
Guess I won't be going of the highway with 4:10 gears  3500rpm would not be fun on long trip.
Offline dutch
Re: Gear ratios
« Reply #3 on: January 26, 2012 - 05:10:43 PM »
same here.... but tons of fun the rest of the time  :burnout: :woo:
*** Bart ***
Re: Gear ratios
« Reply #4 on: January 26, 2012 - 05:28:02 PM »
If you have a 440 4-speed, no problem going with 3:23.
You can still chirp the tires at red lights, and you can drive all day on the highway.
Do you have any engine upgrades from a stock engine?
Offline PlumCraZRT
Re: Gear ratios
« Reply #5 on: January 27, 2012 - 05:40:36 PM »
It's probably worth mentioning that I used to have a 3.23 rear with 235/60R15 tires.  I switched the rear to a 3.55 unit when I had the rear rebuilt, but I also switched to 275/60R15 tires.
Between the height change on the tires and the change in ratio, the freeway RPM is the about the same (~2% difference).  Something to think about if you have a specific tire in mind or not.
mmmmm.... Mopar.... *drool*
Offline Fern
Re: Gear ratios
« Reply #6 on: January 27, 2012 - 08:08:22 PM »
Great advice
Thanks
by the way its a stock 440 with 906 heads
