Author Topic: Road Lamp Wire Routing and Switch Mounting  (Read 3039 times)
Offline t3374jg
« on: January 26, 2012 - 09:20:24 PM »
I am adding Road Lamps to my 70 Barracuda and I am looking for help with the wire routing and the Switch mounting. Ideally, wiring graphics or photos would be appreciated. I would also appreciate any tips I may need for possible issues I have not even considered yet. Thanks
Offline 4 speed fish
Re: Road Lamp Wire Routing and Switch Mounting
« Reply #1 on: January 26, 2012 - 11:21:07 PM »
Standard dash or Rallye dash,location of the switch is not the same.
Offline t3374jg
« Reply #2 on: January 27, 2012 - 05:33:27 PM »
Rallye dash. Thank you for asking.
Offline FY1Cuda
« Reply #3 on: January 27, 2012 - 07:17:35 PM »
Firewall routing:
« Reply #4 on: January 27, 2012 - 07:50:04 PM »
The switch mounts on the dash frame under the heater controls on the left side of the controls,you should have hole in the dash frame where is goes,run the wires along the inner fender behind the battery down to the lamps.Do you have the roadlamp relay switch?
Offline t3374jg
« Reply #5 on: January 27, 2012 - 11:37:51 PM »
As a matter of fact I do not have a relay. I have the wire arness and the lamps but no switch and no relay. Any recommendations for obtaining these items. Thank you kindly.
« Reply #6 on: January 28, 2012 - 12:16:43 PM »
The switch and relay will come up  on ebay alot.
Offline FY1Cuda
« Reply #7 on: January 31, 2012 - 01:20:08 AM »
There are a number of the switches available on Moparts (E-body Parts) but they're pricey.
Offline swede-cuda
« Reply #8 on: February 02, 2012 - 01:08:46 PM »
Firewall routing:
  :clueless:  :dunno: ,where it says -cuda clutch safety switch,thats where the road-lamp grommet/wire should be... :pullinghair: please correct me if im wrong.  :cooldancing:
Offline 67vertman
  • Member since 9-23-2005
« Reply #9 on: February 06, 2012 - 10:55:22 AM »
here is a diagram for the wire running.
