Author Topic: Fuel lines  (Read 1548 times)
Re: Fuel lines
« Reply #15 on: February 26, 2013 - 07:49:42 AM »
I've read that using a return line makes the pump ( mine's electric) last longer by not "dead heading" it? It also runs quieter.  I followed Mallory's recomendations as the size of the fuel line was the same cost wise as I had to replace everything ( including the sender, installed a 1/2") anyway as my car was opriginally a /6.  I didn't get a lot of  driving in before winter came but as Neil mentioned it also allows for cooler fuel. I did have issues with fuel bouiling in the carb before ..... not now. Also after sitting for a few weeks the fuel bowls would be dry, an electric pump also solved that issue for me.
Here is where/how I plumbed in the return line.
 A few more pictures of the lines, pump, filter....
I bought all the fittings and flex line from here. Much cheaper than Earls, Areoquip etc....
http://www.anfittingsdirect.com/
Offline cudabob496
Re: Fuel lines
« Reply #16 on: February 26, 2013 - 01:41:19 PM »
Looks like a heat shield may be helpful where the lines are close to exhaust/mufflers?
2011 Kawasaki Z1000
Re: Fuel lines
« Reply #17 on: February 26, 2013 - 02:36:38 PM »
 I installed fireproof sleeving like what was shown in the one loose fitting were the lines came close to the exhaust.  :2thumbs:
