Ok, so i put down the popcorn and actually did a bit of work today. Aired up the tires put it back on the ground and rolled it out into the beautiful sun today. And that was about the end of the easy bit. The drivers side fender had been replaced at some point and whoever did it, did not know what a u-nut/nut plate is. so EVERYTHING had a nut on the other side. Not even a normal nut, a stinking nut with silicone on the inside... Now i know why that used that kind, but that was a huge pain the ass
but then as I get towards the end, and can see the light at the end of that tunnel, I find that they even nicely put a nut in between the fender and the grille filler panel. after almost 45 minutes getting one of them out, I Couldnt take it anymore and Mr. Sawzall to the rescue for the last bolt. So now the front of the car looks like this
here is an inside shot with most everything removed:
The new metal that is just waiting to be installed (front/rear/footwell floor pans, trunk floor, and trunk dropoffs)
My sad looking lower back seat (oooohhhh! that might just be a build sheet!!)
Sorry to get your hopes up, but this is all that was left of the poor build sheet:
So All in all it was a productive day, I need many more like that in order to get this done within the next 10 years though. I will be making a resto page as soon as a think I've actually started restoring the car instead of just taking it apart. oh, and what is the name of the part that is below the grill and bumper, it has the fog lights in it. You can see it in the upper right hand corner of this final comedy picture. just look how i had to take the think apart
Joe
