Author Topic: sand blasting swaybars  (Read 2083 times)
« on: February 02, 2012 - 11:37:13 AM »
Can the front sway bar be sand blasted to clean it up or will it weaken the bar?  My original one is a rusty mess.
Re: sand blasting swaybars
« Reply #1 on: February 02, 2012 - 04:22:26 PM »
I don't think you will weaken it any by sand blasting it. It's over an inch in diameter, right?
« Reply #2 on: February 02, 2012 - 04:27:12 PM »
I just didn't know if the sand hitting it would cause any stress...then when it starts twisting it would snap.  I know torsion bars are sensitive to any nicks.  Just wanted some opinions before I have the swaybar blasted.  I'd rather ask now then have to buy another one because I didn't ask.
« Reply #3 on: February 02, 2012 - 11:18:00 PM »
What about making a tray to put it in and cover with either Evaporust of diluted Molasses?
« Reply #4 on: February 02, 2012 - 11:47:23 PM »
I thought about that.  The front bar would be a lot easier then the rear bar that's for sure.
« Reply #5 on: February 02, 2012 - 11:51:56 PM »
Molasses works good. I tried it before. About 1 part Molasses to 3 parts water. Takes longer but does the same as evaporust. Alot cheaper. Rear sway bar...eh, that would be tricky to soak.
« Reply #6 on: February 03, 2012 - 09:18:14 PM »
glass bead would harden the bar without nicking the surface , I just wire wheeled mine on a bench grinder & hit ti with Eastwood Rust encapsulator
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #7 on: February 03, 2012 - 09:39:42 PM »
Sandblasting will definitely "case harden" metal objects.  I had my blast cabinet loaded with glass beads and turned the pressure down.  I really doubt that either sand or bead blasting would harden the surface anymore than it already is----but why chance it! PK
The Brewmaster
Offline PlumCraZRT
« Reply #8 on: February 07, 2012 - 03:57:25 PM »
You mean "work harden", not case harden.  Peening will work harden a surface to improve its resistance to fatigue (by creating local compression in the material)... not sure sand blasting will do a whole lot.
EDIT:  Meant to say that I'm not sure sand blasting will do much to the existing steel (it should have no problem removing the rust).
« Last Edit: February 07, 2012 - 06:45:32 PM by PlumCraZRT »
mmmmm.... Mopar.... *drool*
« Reply #9 on: February 07, 2012 - 04:58:57 PM »
 :iagree:  I did the same, except I got a wire wheel for my disc grinder. Works really well, did lots of parts with it. K-frame, LCA's , rear end housing etc......
