Author Topic: steering noise  (Read 531 times)
Offline 74challenger03
steering noise
« on: February 06, 2012 - 03:45:35 PM »
steer wheel makes noise when i turn it,any clues why?I took it apart to replace the bearing housing it was damage.Did not find any broken pieces.bearing in housing was not bad looking at it.Will try to put up pics tonight.Wife has to do it. LOL    thanks Dave
Offline Gumby
Re: steering noise
« Reply #1 on: February 06, 2012 - 04:25:52 PM »
Was it making noise before the bearing inspection? Can you hear it inside the car or outside the car? Does it bind up? What kind of noise? Did you have someone turn the wheel back and forth (car running IN NEUTRAL) and look underneath to check all components? etc.Just some tips on maybe chasing the gremlin down!
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
Offline 73Chally
Re: steering noise
« Reply #2 on: February 06, 2012 - 04:27:39 PM »
power steering or manual?  If power steering, it could be the pump.
Re: steering noise
« Reply #3 on: February 06, 2012 - 05:13:57 PM »
none of the above,it is coming from the column inside the car.thinking the can and bearing housing are rubbing . Will be putting a tread up tonight on changing bearing housing.
