Author Topic: pitman shaft seal replacement  (Read 1217 times)
« on: February 11, 2012 - 11:07:10 AM »
The search function is broken right now so I couldn't look for past posts...
A complete power steering rebuild isn't in the budget right now and I'm not comfortable tearing the box apart myself.  I did buy a pitman shaft seal kit though and was wondering the easiest way to replace it.  I read where someone said to remove the snap ring...then start the car.  The pressure would pop the seal.  My PS box is out on the bench and it also has a dust seal below the snap ring.  How do I get these seals out with the pitman shaft still inplace?  Thanks
Re: pitman shaft seal replacement
« Reply #1 on: February 11, 2012 - 11:38:49 AM »
Use a dent puller type that screws in. The old style type works.
« Reply #2 on: February 11, 2012 - 12:04:09 PM »
I'm not sure what you're talking about?  Can I just drill a small hole in the seals?  THen run a screw into them to pull with?
« Reply #3 on: February 11, 2012 - 12:06:07 PM »
yeah, that'll work. One on each side then use the edges as leverage with vice grips.
« Reply #4 on: February 11, 2012 - 07:27:51 PM »
That worked great.  The box is cleaned up and the seals are installed.  I'll degrease the box on Monday and paint it black.
Offline don340-4
« Reply #5 on: February 12, 2012 - 12:00:02 AM »
 burdar, if you have the box on the bench you might want to replace the steering shaft seal, they can be tough to replace while the box is in the car.
      :wavingflag:
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
« Reply #6 on: February 12, 2012 - 12:11:55 AM »
Looking at the expanded picture of the box, I really don't want to get into that mess.  The locking rings are probably not going to come loose without a fight either.  If the box leaks, I'll send it in for a complete rebuild.  Right now I need to focus on getting it on the road.  Thanks for the suggestion though.  I really thought about getting the complete seal kit.
« Reply #7 on: February 12, 2012 - 05:55:30 AM »
Mine was not black....just rusty
« Reply #8 on: February 12, 2012 - 09:44:06 AM »
I remember you saying that when we talked earlier.  Mine looked natural too(completely rusty) so I painted it a cast color.  After reading a lot of posts about the power boxes being black, I started looking for pictures of 73/74 cars.  I've got a picture of a survivor 74 Cuda with a black box and a few other cars with remants of black paint.  Everyone I talked to said the black paint didn't stick very well.
Yesterday, I applied paint stripper to the box and as I scraped the cast paint away, I saw black paint coming off too.  While wire wheeling the entire box, there were a couple areas where the black paint showed up.  I kind of like the cast look better but will be painting it with Eastwoods Extreme Chassis Black...a little less gloss then the K-member.
