Author Topic: Trans experts! Here's a challenge for you...  (Read 3970 times)
Offline sadil340
Re: Trans experts! Here's a challenge for you...
« Reply #15 on: February 18, 2012 - 07:48:10 AM »
Weird , at least we are onto figuring it out good or bad .
do any of the shafts have excessive end play / bad brgs or bushings ?
The input shaft moves around a bit but I was told that it uses ball bearings so that is normal. The tailshaft seems pretty tight. We haven't broken the trans down yet to check inner shafts but that may be a strong suspect. The fact that acceleration causes the problem tells me it's something causing the gears not to line up properly but that's just a guess.
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
« Reply #16 on: February 18, 2012 - 09:20:23 AM »
the front shaft will move side to side a little but should not move in & out at all .
 what type of shift / side cover do you have , the double level or the ball detent ?
Offline sadil340
« Reply #17 on: February 18, 2012 - 11:54:16 AM »
Good to know, it doesn't move in and out. I believe it's the double level type - there are two levers for the detents. Is that what you mean?
3:55 SureGrip
Owned since 1974
« Reply #18 on: February 18, 2012 - 03:13:22 PM »
is there a E clip on the outside of the shift cover ?
If so it is the doulbe lever interlocking both shift forks
Offline sadil340
« Reply #19 on: February 20, 2012 - 04:58:23 PM »
No there are only the fittings where the linkages bolt on and the cover attachment bolts. No clips that I could see...
Here are some shots of the B-Body cover, it's the same design:
« Last Edit: February 20, 2012 - 05:10:02 PM by sadil340 »
3:55 SureGrip
Owned since 1974
« Reply #20 on: February 21, 2012 - 07:46:45 AM »
Ok the alum cover retain the pin for the lever with a snap ring , the steel cover doesn't
Offline sadil340
Re: Trans experts! Here's a challenge for you... closin' it out
« Reply #21 on: February 25, 2012 - 07:48:24 AM »
Well I'm done. Moving the linkage cover around does change the shift behavior but doesn't fix the problem. I'm throwing in the towel and buying a rebuilt trans. If down the road I figure it out I'll post the answer.
Thanks everyone (especially Neil) for your helpful suggestions!
3:55 SureGrip
Owned since 1974
Offline 4 speed fish
« Reply #22 on: February 25, 2012 - 05:32:37 PM »
I pulled my tranny 4 times before I waved the flag,bought a new one and all is good.
« Reply #23 on: February 25, 2012 - 08:47:52 PM »
I wonder where the issue is ?? it could just be worn out .
 Glad I could try to help anyway  :2thumbs:
Offline sadil340
« Reply #24 on: February 28, 2012 - 09:06:41 AM »
I hear ya! Can do it in record time now.
3:55 SureGrip
Owned since 1974
