Author Topic: Rim specs  (Read 833 times)
Offline Fern
Rim specs
« on: February 12, 2012 - 10:33:03 AM »
Are rims with 5 x 4.5 the same as 5 x 114.3 ?
Offline CarelianCuda
    • http://bot.fi/3gu
Re: Rim specs
« Reply #1 on: February 12, 2012 - 10:39:41 AM »
Yes it's the same: 1 inch is 25.4 mm, so 4.5" x 25.4 = 114.3 mm
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
Re: Rim specs
« Reply #2 on: February 12, 2012 - 01:00:05 PM »
But check the backspace carefully. A rim advertised in metric specs may be a later model verison with excessive backspace that may not fit on a classic mopar. Many of these do fit okay, but not all.  check and double check to save yourself grief.
Offline Fern
Re: Rim specs
« Reply #3 on: February 12, 2012 - 01:06:04 PM »
So how is the backspace measured?
    • http://bot.fi/3gu
Re: Rim specs
« Reply #4 on: February 12, 2012 - 02:30:41 PM »
Offline Fern
Re: Rim specs
« Reply #5 on: February 12, 2012 - 04:14:43 PM »
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Rim specs
« Reply #6 on: February 12, 2012 - 05:11:50 PM »
Also to complicate things watch out for the center hub hole opening.  Mopars tend to use a larger hole, about 2.75" where many applications use a center hub hole of 2.5".
An example is if you wanted to use some Ford rims on our cars, ie late Mach 1 or Bullit style rims up to 2004.  The bolt pattern is good but the center hub hole is 2.5" (too small) and also the back space is like 5.5-6.0", too deep and our tires will rub the front suspension or leafsprings.
The hub hole issue is moreso the front with disc brake setups.
