Author Topic: Challenger Fender 'scoops'/scallops/ swoopy trim things  (Read 3778 times)
Offline dawerks
« on: February 14, 2012 - 11:49:49 AM »
Ok, so I don't even know the correct term for it!  But they are on both front fenders.  They're black and they are the pot metal fender 'strakes' where the pencil stobe decals start from.
The driver one is in good shape, all there.  The passenger has 3 mounting tabs broken off but it was still holding fine on my car.
I have no idea what it's called so obviously I have no idea what to ask, just offer away!  :)
Offline Jamiez
  • Retro
Re: Challenger Fender 'scoops'/scallops/ swoopy trim things
« Reply #1 on: February 14, 2012 - 11:54:00 AM »
I believe the correct term is "Simulated Fender Louvers"  They would have been fender tag code M08 or as part of the A57 rallye package :)
They are 2 pieces, an outer and an inner.  I believe the inner is repopped but the outer isn't.  Having the stakes intact makes them worth more as they tend to break.
Offline dawerks
« Reply #2 on: February 15, 2012 - 01:02:24 AM »
Ahh yes!  Of course! :)  Thank you for the correct terminology!
The inner and outside are there for both sides.  The only thing wrong is the mounting tabs on the passenger side are broken (3 of them) but the other 3 (?) are still there.  The strakes themselves are fine.
Offline Buddhascuda
« Reply #3 on: February 16, 2012 - 09:22:14 AM »
what r u asking
2003 silverado quad steer
81 harley stroker superglide
73 doge challenger 340 rally
2003 venture {the wifes}
2003 25' travel trailer
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: February 21, 2012 - 09:37:51 PM »
 :wave:  Any pics? How much are you asking for them?
Offline dawerks
« Reply #5 on: February 21, 2012 - 11:33:34 PM »
I will get pics, promise!  And what's a reasonable price for them? :)  I would like someone to get good use out of them, I welded/shaved my fenders.
« Reply #6 on: February 22, 2012 - 04:18:45 AM »
Just curious, you prefered your fenders without the fender louvers?  Is yours a Rallye car originally? :clueless:
Offline dawerks
« Reply #7 on: February 22, 2012 - 12:46:48 PM »
Mine is a Rallye but I am going for a smoother look.  These look a little awkward on the car :)
These would look better on a restoration.
« Reply #8 on: February 22, 2012 - 06:41:46 PM »
Cool, yeah, depending what you're looking for and stripes yoou use and such the louvers sorta get in the way.
« Reply #9 on: February 22, 2012 - 08:08:14 PM »
Tony's Parts sells the plastic inserts.  Originals are commonly broken.
I paid $100 for a pair of louvers that had all the pins intact.  The one with pins broken isn't worth much if anything IMO.  You should be able to get $50 for the good one.
If the three center pins on the flared sections are intact, the passengers side louver probably can be fixed.  There might be enough material behind the pins to drill/tap them for studs.  There is no extra material behind the three center flares though.
« Last Edit: February 22, 2012 - 08:10:57 PM by burdar »
Offline dawerks
« Reply #10 on: February 23, 2012 - 02:37:05 AM »
Cool, thank you!  How about $75 for everything (2 outside, 2 inside).
