Author Topic: Magnum strut replacement  (Read 1543 times)
Offline moparnut
    • My Photo's
« on: February 14, 2012 - 10:55:11 PM »
Hey all
I hope this isn't too far off topic, but I need some help or sites on the process of replacing front struts on my 2006 dodge magnum rear whelk drive
Thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Re: Magnum strut replacement
« Reply #1 on: February 15, 2012 - 08:13:51 PM »
front struts are simple to swap out . 3 nuts up top , remove the sway bar & lower bolt , split the ball joint , I just use a hammer to pop them apart ,  push the lower control arm down & remove the strut . If you have to remove the spring you need a good spring compressor .
