Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
help with rallye tach - wiring diagram?
« previous
next »
Print
Pages: [
1
Author
Topic: help with rallye tach - wiring diagram? (Read 1647 times)
The4ork
Jr. Member
on:
February 15, 2012 - 09:11:53 AM »
i need to figure out how to wire it up correctly to work (none of my gauges work except the ammeter) and have it run off of an MSD Streetfire box
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: help with rallye tach - wiring diagram?
Reply #1 on:
February 16, 2012 - 10:10:37 AM »
there are 2 wires at the factory tach , blue 12 v power & a grey signal wire , the grey wire needs to connect to the MSD but you may need a tach adapter to eliminate the multi spark signal under 3000 rpm so ti will read properly .
Logged
The4ork
Jr. Member
Reply #2 on:
February 17, 2012 - 02:17:56 AM »
and im guessing it grounds out through the housing?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
February 17, 2012 - 08:53:12 AM »
yes , there is no external ground wire
Logged
The4ork
Jr. Member
Reply #4 on:
February 18, 2012 - 01:07:35 AM »
so should i try running the grey input wire to the tach output off the msd box to see if it works without the filter?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
February 18, 2012 - 09:28:17 AM »
you can try it , it will not blow up the instrument, it just wont read correctly
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
