Author Topic: Door locks  (Read 1326 times)
Offline Katfish
  • 70 Challenger
Door locks
« on: January 28, 2005 - 04:08:40 AM »
Has anyone converted / modified the 70 door lock mechanisms?
I believe it's a 70 only feature, but you have to lock the doors with key.  You just can't push down inside lock and close door.  This is inconvient for passenger side.
I recall my 72 didn't work this way.
Katfish
Re: Door locks
« Reply #1 on: January 28, 2005 - 01:52:55 PM »
I got tired of that too & bent a small tab on the mechanism that changes it so you can push the buttom down to lock it & shut the door & walk away , much better this way & not hard to do , didyou get the Shifter yet?
Offline Katfish
  • 70 Challenger
Re: Door locks
« Reply #2 on: January 28, 2005 - 05:09:10 PM »
CP,
Yes, last week.  I sent you a PM.  Thanks again!
Got anymore info, or maybe a picture on what to do for the door lock?
Thanks,
Katfish
Re: Door locks
« Reply #3 on: January 29, 2005 - 01:20:51 PM »
I did mine 20 years ago , if you pull off the door panel & operate the latch you will see the arm that un locks it just bend it so it doesn`t unlock the door as the latch is closed
Offline Katfish
  • 70 Challenger
Re: Door locks
« Reply #4 on: January 29, 2005 - 02:20:24 PM »
Thanks,
I'll take a look.
Offline gomopar440
Re: Door locks
« Reply #5 on: February 01, 2005 - 06:26:23 AM »
It's been a while since I've used a door lock mechanism on a 70 challenger. IIRC I think your'e supposed to lift the outer handle at the same time you push the lock lever down to make it latch. Like I said, it's been a while, so I may be wrong on this one. :dontknow:
