Author Topic: dash-worx kit for hooking up non-rallye wire harness to work on rallye gauge  (Read 2431 times)
Offline mickey
Anybody try this kit dash-worx sells? be  able to hook up a rallye cluster to a non rallye wiring harness. thxs :feedback:
« Last Edit: February 21, 2012 - 11:50:40 AM by mickey »
the only difference between the two is the added power wire for the tach & clock & the tach feed wire to the coil , the rest of the dash wiring  is the same just the wire lenghts are different for the different positions of the guages & lights
Offline 73Chally
Don't you still need the big plug that goes to the back of the 4 gauge pod, or is that not part of the kit?  I swapped out my non-rallye cluster a few years ago, but I was able to hack up a rallye harness to get what we needed.
no gang plug on the ralley dash
Offline 73Chally
Okay.  I must have been thinking about it backwards.
Offline mickey
So there is no need to purchase a kit , i can make my non-rallye harness  to work with a rallye cluster? thxs neil
yes , you will have to extend a few wires to reach , & add a battery power for the clock & a switched power for the tach & add the tach signal wire  . The oil wire feeds a light on the std dash  but will connect from the guage to the sender & you need a different sender unit .
Offline mickey
Neil different oil sender you have a pic? thxs for reply.  im confused on the placing of the wire s on tach  any diaghram you may have pointing to the studs on tach. appreciate the help mickey
You need this oil pressure sending unit for a Rally oil pressure gauge.
I don't have any pics of the back of a tach. Darnit!!    :stomp:
2 wires to theback of the tach , blue for power & grey for signal , one is a spade lug the other is a bolt on terminal but which is which ?? :banghead:
Yeah,
  The BIG question.   :grinyes:  Screw it up and your tach is toast.  But I don't have a picture darnit.   :banghead
I think the gray wire for the signal is the spade lug. I'm almost positive...   :22yikes:
Offline mickey
Thxs for reply's should be on right track..
