Author Topic: 340 6 pack - possible too add a/c?  (Read 3713 times)
Offline 340_6pak
Re: 340 6 pack - possible too add a/c?
« Reply #15 on: February 24, 2012 - 10:38:43 PM »
It is a sanden unit.
73 Challenger
340 6pak
Offline Sean
    • My Cuda Restore
« Reply #16 on: February 25, 2012 - 12:05:07 PM »
Offline cuda346pk
« Reply #17 on: February 25, 2012 - 11:56:10 PM »
Remember, this is a 340, not a big block.
What air cleaner assembly are you running? The base plate is smaller than mine. I have not tried to identify mine yet, here are some pics in case someone can tell easily what it is off, maybe it is an original AAR one as the 2nd owner did buy a real complete setup off a buddies Purple AAR in the late 70's.
Are you running the Vintage Air system? Did that compressor originally mount with the lines running straight up?
I assume based on what I can see of your belts you are not running power steering, what is the belt configuration on yours?
David - In Georgia
1972 'Cuda In-Violet 340 6 Pack 4 Speed 3.91 Sure Grip - Finally, after 27 years of waiting and dreaming it is real. Now the fun begins!
Offline 340_6pak
« Reply #18 on: February 26, 2012 - 05:53:34 PM »
It does have power steering, and the air cleaner came with the 6 pak package, hollys with vacuum, not mech linkage. The compressor came like you see it and I think the ac package came from vintage.
73 Challenger
340 6pak
Offline cuda346pk
« Reply #19 on: February 29, 2012 - 11:57:19 PM »
It does have power steering? I thought when there was power steering and A/C the belt setup was - crank - ac - alternator on one or double belt and crank - water pump - power steering on another. Am I correct that yours looks like crank - ac - power steering, and the other being, crank - water pump - alternator?
David - In Georgia
