Author Topic: Steering column ?  (Read 541 times)
Offline challengerx
Steering column ?
« on: February 21, 2012 - 11:06:45 PM »
Ok, I have the column all bolted in and installed my non rallye gauge cluster but when I tighten the nuts on the column studs it draws the column so tight that the key release hits the bottom of the cluster. Am I missing a spacer under the dash. Thanks.
Offline 74challenger03
Re: Steering column ?
« Reply #1 on: February 23, 2012 - 07:08:48 PM »
my 74 challenger is the same way,dont know about spacers.
Offline challengerx
« Reply #2 on: February 23, 2012 - 09:14:57 PM »
I guess I will just use some type of spacer then because no matter what I do the key release hits the gauge bezel.
« Reply #3 on: February 24, 2012 - 05:54:21 AM »
if you loosen the 2 bolts holding the column & pull the column should slide up 1/2 or so
