Inside hood release cable routing
Author Topic: Inside hood release cable routing  (Read 3541 times)
Offline 71340RT
« on: February 26, 2012 - 10:53:19 PM »
I have a inside hood release and would love to use it. I don't know how it is routed or where it goes through the firewall and would like to see some pictures of how it goes from the dash forward.
Thanks, Jeff
« Last Edit: February 26, 2012 - 10:55:05 PM by 71340RT »
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline eastcan
Re: Inside hood release cable routing
« Reply #1 on: March 31, 2012 - 05:27:14 PM »
In the process of restoring my car and have no clue how to route the remote hood release cable through the firewall out to latch.  Can someone help?
« Reply #2 on: April 01, 2012 - 10:18:01 AM »
I believe it goes out through the large washer pump grommet & was run with the wiring past the battery & out where the headlight harness runs
Offline walkAbout
« Reply #3 on: April 10, 2012 - 05:04:21 PM »
I will mount mine in the next weeks. And yes it will run with the headlight harness. Not sure if it where like this, but AFAIK 1970 where no remote hood release option available. I can take pictures if you like. I have a huge hole in the firewall next to the brake booster.
CU
walkAbout
Offline RB2929
« Reply #4 on: April 11, 2012 - 07:42:43 AM »
A better question is: where does the handle mount under the dash?
My car didn’t come with the hood release from the factory, so there’s no obvious screw holes.
Also, I noticed that the cable itself seems too long to work.  There’s about a foot of slack in the cable thus, when the handle is pulled, not enough tension to pop the hood catch mechanism.
- The hood release cable is brand new and when compared to pictures it appears to be correct (it doesn’t look like a C-body handle)
Your advise is greatly appreciated
Offline walkAbout
« Reply #5 on: April 11, 2012 - 02:48:12 PM »
I already tried mine. There is an other thread here, where I got the advise. 73 Challenger hood release I tried the handle again and it will not be completely vertically. Maybe I have to put some washers under one side (afair left hole) and use a longer screw. Let's see...
I have an original cable and had the feeling, that it will fit, but had to mount first the metal holder to the hood latch grille support brace. Now it looks like on the second picture. The first picture shows it working from an other Challenger. I can measure my original cable if you like.
CU
walkAbout
Offline 71340RT
« Reply #6 on: April 16, 2012 - 10:22:22 PM »
Thanks for the info and he pictures. I will try and run mine this week if I have time.
