Author Topic: 509" Blueprinted Indy Motor w/Dyno and Vid!  (Read 4176 times)
Offline Da_Cuda
  • OOoooo... Barracuda!
    • Backyard Turbo - PROVEN Performance!
« on: February 27, 2012 - 11:20:34 AM »
73 Cuda
Indy 500" Motor Package
Blueprinted and bored slightly further - 4.42" Bore/4.15" Stroke
Indy SR Heads, 11:1 CR
Comp 23-631-5 Cam, 1.6 Ratio Rockers
Dual Valve Springs (not sure what the pressure is)
Indy 440-2 Intake Manifold, Custom Machined Holley 850 Double Pumper
MSD Pro Billet Distributor, Firecore 50 Wires, MSD HVC-II Coil
Hedman 2" Headers, Dual 3" Exhaust
G Force Built T56, Dana 60 Rear w/4.10 Gears, pulls in 4th gear
Im going to swap to either a Ultra HP 950 Carb or a 1000 HP w/Annular Boosters, Im open to discussion on which is a better choice, I really can't decide yet!
Island Dragway open next Sat (March 10th) so Im excited to run it after the dyno tuning!  We picked up quite a bit since I first got the car running.  Still debating if Im going to run on just the DR's or bring the Slicks along also and run them a pass or 2.   :burnout:
73 'Cuda - Blue w/Black Vinyl Top
509" (4.42 Bore/4.15 Stroke), 11:1 CR, Indy SR Heads, Indy 440-2 Manifold, Comp XTQ286S, 1.6 Roller Rockers, Dual Valve Springs, Hedman Husler 2" Long Tube Headers, MSD Billet Distributor, MSD HVCII Coil, Firecore 50 Wires, Holley 850 Double Pumper (choke box machined off), Aeromotive A1000 Fuel Pump, Custom Return Style Fuel System, Mallory Rail and Regulator, Derale Fuel Cooler, G Force T56, Dana 60 w/4.10 Gears.
Art Morrison Ladder Bars, Sub-Frame Connectors, Custom Roll Cage, Boyd Coddington F-09 18" Wheels, QA1 Coilovers, Koni Adjustable Shocks, AAR Rear Spoiler, Hemi Duster Hood Scoop.
Re: 509" Blueprinted Indy Motor w/Dyno and Vid!
« Reply #1 on: February 27, 2012 - 06:06:54 PM »
 :2thumbs: looks cool, but a few questions
No head port work?
Why no open n closed spring pressure?
What is that cam. Looks like it might be on the small side
« Reply #2 on: February 27, 2012 - 06:31:53 PM »
At first I thought that was engine #'s then I realized that  at the wheels!  :wow:  That's gonna be fun! Good job!
 :clapping:
Offline Da_Cuda
« Reply #3 on: February 27, 2012 - 10:28:17 PM »
I don't know the valve spring pressures, I talked to the motor builder recently but that was one thing I didn't ask.  The heads are the SR heads and they weren't ported, just the max wedge intake port style.  The cam is ~600 lift and 300ish duration when you add the rocker ratio in.  Its a street driver that I take to the track also.  Im also a turbo builder normally and I inherited this car as is, when the motor gets tired or I get bored I plan to drop the CR to 10:1 and throw a pair of 7064 EFR Turbo's on it :)
Offline Da_Cuda
« Reply #4 on: February 27, 2012 - 10:30:13 PM »
The fuel pump died on my way home today btw :( I just can't win with this car lol, I have spent tons of money getting it going and its quickly becoming a money pit!  At least its a car that's worth it tho and not some 88 Civic ****box lol
Offline joelson6
« Reply #5 on: March 28, 2012 - 09:48:21 PM »
Island Dragway? i'm guessing your talking Jersey.
i live by Ft. Dix.
