Author Topic: overhead console install in a non-OC car?  (Read 6398 times)
RedLine
Re: overhead console install in a non-OC car?
« Reply #15 on: December 22, 2005 - 09:51:45 PM »
Part 2 of Question 2
« Last Edit: April 10, 2006 - 06:57:47 PM by Rev-It-Up »
RedLine
« Reply #16 on: December 22, 2005 - 10:20:17 PM »
on Question 1 -- was this the pic you saw?  yes, it is key to holding the console up (and sandwiching the headboard) -- it also has a stud you see for the console to be attached through the headboard.
« Last Edit: April 10, 2006 - 06:58:04 PM by Rev-It-Up »
Offline gomangoRT/SE
« Reply #17 on: December 22, 2005 - 11:34:29 PM »
Excellent diagram and explanation Redline....      As I have an unassembled RT/SE I appreciate it.... :wow:
Offline miketyler
    • www.miketyler.net
« Reply #18 on: December 23, 2005 - 05:15:06 AM »
yes, Red that is exactly the info I was looking for. Your illustrations are spot on. I appreciate you taking the time to lend us some guidance here. Hopefully, I will get a chance to return the favor
  :biggrin: :naughty: :biggrin:
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
RedLine
« Reply #19 on: December 23, 2005 - 06:50:32 AM »
Y/W guys.. glad to help   :thumbsup:
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #20 on: December 27, 2005 - 11:56:38 PM »
mike, as far as the door switches, mine are seperate. the switch by the hinge does the dome light. A seperate switch by the striker does the console door ajar light.
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline miketyler
    • www.miketyler.net
« Reply #21 on: December 28, 2005 - 05:02:15 AM »
thnaks for that info, are the switches like the hinge side switches or are they the plastic type?
Also, where are they located relative to the striker? Someone on Moparts said there is a factory dimple at the switch locations on non 'door adjar' cars but I cant see them on mine
72' Cuda restomod
70 Mustang Mach 1
  • HvacMan
« Reply #22 on: December 28, 2005 - 10:57:43 PM »
It's metal like the other, but the nut around it is a little deeper/thicker in appearance.
If you get down eye level with the striker it's about 2'' to 2-1/4'' lower. there's one for both doors.
Let me know if need u anything else.
Eric
Bay Area California
Offline miketyler
    • www.miketyler.net
« Reply #23 on: January 10, 2006 - 04:50:07 PM »
cool - I got my wiring today; I know there is a low-fuel relay for the low fuel indicator but isnt there a time delay relay for the "fasten seat belt" reminder?
72' Cuda restomod
70 Mustang Mach 1
Offline FY1 RT SE
« Reply #24 on: January 10, 2006 - 07:38:01 PM »
It connects to the time delay wiring harness.
Offline miketyler
    • www.miketyler.net
« Reply #25 on: January 10, 2006 - 08:26:28 PM »
so it was unique to an o/h console car or any Ebody car already has this? Need to know if I am still short some parts here
72' Cuda restomod
70 Mustang Mach 1
Offline FY1 RT SE
« Reply #26 on: January 11, 2006 - 09:37:55 AM »
The time delay harness is used with the A01 light group option.
Offline miketyler
    • www.miketyler.net
« Reply #27 on: January 11, 2006 - 05:48:19 PM »
I dont have an A01 on my fender tags so I guess I am one of the "have-nots". That relay is pretty simple though. Maybe there are equivalents out there?
72' Cuda restomod
70 Mustang Mach 1
Offline FY1 RT SE
« Reply #28 on: January 11, 2006 - 09:41:37 PM »
All models had the A01 package available as an option. connectors and wire lengths etc. were different.  Here is a '70 E body harness.
Offline miketyler
    • www.miketyler.net
« Reply #29 on: January 12, 2006 - 10:57:46 AM »
you are correct - got one of those for sale? Do you happen to have the schematic showing how that interfaces with the o/h console wiring? That would be an immense help. None of this stuff is in the 72 manual   :dunno:
72' Cuda restomod
70 Mustang Mach 1
