Author Topic: tons of parts  (Read 867 times)
Offline cudadan360
tons of parts
« on: February 29, 2012 - 09:02:49 PM »
cleaning house
426 hemi flywheel resurfaced,$174
Indy SR heads for BB new valves, springs, reatainer, and keepers, $`1200 just in port work  $1500
Indy cyl head bolt kit  Sr heads $30
 Biondo throttle controller  SHS NEW $195
727 trans shield $75
BB mopar water pump housings NEW $140 used $100
moroso elctric water pump drive kit NEW $60 used $40
 Comp cams BB mopar roller lifters very low miles $300
BB mopar Crane roller rockers with hardened shafts complete low miles plus with extra rockers, $400
BB mopar Harland sharp roller rockers complete like new$600
RB mopar  intake ported std head $150
RB edelbrock TM7 $60
Rb mallory unilite dist$175
B&M 2400 stall used 2wks part# 10415 $150
 SB mopar adj rockers (273 type) complete with shafts and extra rockers $150
SB  edelbrock air gap $200 new
NEW SB+BB main bolts $25
NEW SS+BB main studs $60
NEW mopar deep crank pulley aluminum $40
holley blue pump used $40
B/M flex plate 727 SB+BB part# 10230 new $65
B/M flex plate 360 ext balanced used $40
MSD 7AL rebuilt by MSD everything new inside $350
indy cly valley cover plated 440$50
Indy Cyl valley cover plate 440 w/removable inspection cover $100
383/400 low deck plate $50
INDY cyl head oil pump ,pick up,lines and fittings $200
MOPAR oil pump shaft and bronze gear for roller cam $100
mopar steel stroker crank for 400 to 451 like new drop in and go $350
Hughes SB stroker crank for 340 to 416 CAST NEW $250
360 mopar crank cut .010 .010  $150
deep oil pans BB + SB 318 to 340 also have 360 deep, with pick ups $75 ea
426 HEMI HEADERS for E+B on car for 2 wks $300
426 HEMI FUEL LINES from fuel pump to carbs NEW $100
400 short blk $450
440 blk std bore $450
1971 400 block thick main block #230 $600
440 steel crank std $250
2 centerline wheels, SMALL BOLT PATTERN 4" new drilled,$275 pr 15x8 3"BS
all parts +shipping from  08084
have pix of every part
856 466 0183 Dan call or text email  fastmetal74@comcast.net
