Author Topic: windshield wiper dash control panel ground  (Read 848 times)
Offline jforest1
« on: March 01, 2012 - 04:34:44 PM »
Read about every windshield wiper problem on the forums and got to work and figured out that my dash panel with the windshield wiper knob on it is not properly grounded, so my wipers won't park, and my 3 speed motor only goes one speed (fast).
That is, until I push the panel in and up.  Then it grounds and everything works properly.  Until I let go and the panel drops and comes out 1/32nd of an inch.
So my question is, how is that panel grounded specifically?  I'd like to correct it both so I can fix the immediate problem and so I have a bigger margin of error when removing/reinstalling it in the future.
I'm also kinda pissed because discovering this problem also ended my streak--I've owned the car since Nov 2010 and I finally got caught in some rain.  The high and dry clock starts over...best time to beat 17 months.
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Re: windshield wiper dash control panel ground
« Reply #1 on: March 01, 2012 - 07:13:18 PM »
If you look on the bottom of your switch panel, where there are 2 screws that hold it in, 1 screw has a metal tab that actually grounds the whole switch panel to the dash. If you removed the panel and looked at the back, you will say....duh
Offline 74challenger03
« Reply #2 on: March 03, 2012 - 09:06:02 AM »
and you might want to add another ground to it.
Offline jforest1
« Reply #3 on: April 06, 2012 - 04:40:21 PM »
Finally carved out 30 minutes to investigate this again and lo and behold, no screw!  Thanks for the help.  Works again!
JF
