Author Topic: 10.95 clutch ??  (Read 1470 times)
Offline gargoyle
  • '70 RT/SE 440 4-spd
10.95 clutch ??
« on: March 01, 2012 - 09:20:35 PM »
Ok, here is the set up..... 440,  130 tooth flywheel, 10.95 23 spline RAM clutch.  Will it fit? Worried   The bolt holes line up....... but... kinda worried something might go wrong
Re: 10.95 clutch ??
« Reply #1 on: March 01, 2012 - 11:12:00 PM »
sounds right , I assume the flywheel is 6 bolt not 8 bolt , I assume you have the alum belhousing ?
Offline gargoyle
Re: 10.95 clutch ??
« Reply #2 on: March 02, 2012 - 01:04:13 AM »
yes, 6 bolt... i "think" it's an alum belhousing?  not to sure though.  how can i tell?  (sorry for the dumb question)
Re: 10.95 clutch ??
« Reply #3 on: March 02, 2012 - 09:55:50 AM »
well the quick way is to put a magnet on it , if it falls off it is alum , if it sticks it is iron LOL
Offline gargoyle
Re: 10.95 clutch ??
« Reply #4 on: March 02, 2012 - 05:43:10 PM »
Right!!??  Ok, so if it's one or the other, how would that fit different?  I guess im worried about this due t my local mopar shop told me that it. WON'T fit. That the 10.95 is for the 11" flywheel. Yearone said the 10.5 and10.95 go on the 130 tooth flywheel.
Re: 10.95 clutch ??
« Reply #5 on: March 02, 2012 - 07:03:17 PM »
the confusion comes from the 130 & 143 tooth flywheel , the iron bel is for the 143 tooth & takes the 11" clutch
the alum bel 130 tooth flywheel take the 10.95"
 both use the same 11" disc the 10.95 is just a designation to make the clarification between the 130 & 143 tooth flywheel .
