Author Topic: Minilites finally installed!!! Pics and a question  (Read 3482 times)
Offline Ford.P51
« on: March 02, 2012 - 09:15:16 AM »
Tires finally came in, got them mounted and balanced yesterday and put them on the car. Here's a few pics
Before:
After:
Closeup:
The fronts are 235 60 R15, rear are 255 60 R15. I'm really happy with this setup, a little drop in both the front and the rear and it'll be just what we want.
Now if I can figure out what's going "tack" "tack" "tack" on the drivers rear wheel/brakes/axle I can get her back on the road. If I touch the brakes the sound goes away. I put rear disc brakes and new bearings on the axles a while ago. This noise appeared then but was just barely audible. With the new wheels/tires its gotten louder now, gonna tear into it this weekend. Anyone ever experience something like this?
1969 Ford Mustang Mach1
1972 Challenger
Offline GranCuda1970
Re: Minilites finally installed!!! Pics and a question
« Reply #1 on: March 02, 2012 - 09:22:48 AM »
After mags with the firehawks look meatier  :2thumbs: Good choice!!
Offline HP2
« Reply #2 on: March 02, 2012 - 09:51:24 AM »
That looks great! 15x8 all around?
« Reply #3 on: March 02, 2012 - 10:00:55 AM »
Wheels are the easiest & quickest way to change the look of the car .
 Nice upgrade
Offline Ford.P51
« Reply #4 on: March 02, 2012 - 10:22:57 AM »
Yep 15x8 all four wheels. Everything has plenty of clearance no rubbing of any kind.
« Last Edit: March 02, 2012 - 10:24:45 AM by Ford.P51 »
1972 Challenger
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: March 02, 2012 - 10:50:58 AM »
Wow!  They look really nice!
As far as the noise, see if the caliper is hitting a weld or something on the inside of the rim.  Had a similar issue years ago when I put a new rim on my brother's T-bird and a big blob of weld was hitting the caliper.  Just ground it down and it was okey doke.  Might be what you have...  :dunno:
« Reply #6 on: March 02, 2012 - 11:43:24 AM »
LOOKS GREAT!  :clapping: :2thumbs:   if you used the stick on wheel weights check to see if it's rubbing on something? Mine didn't like where they were and left and found a new home?
Offline Ford.P51
« Reply #7 on: March 02, 2012 - 12:11:57 PM »
Thanks for all of the compliments!
Hadn't thought of the caliper rubbing the wheel or the wheel weights. I'll check that out. Something simple like that would be awesome.
It did make a "tick" sound with the old wheels, now its much louder.
1972 Challenger
Offline V02Barracuda
« Reply #8 on: March 02, 2012 - 01:08:58 PM »
Wheels and tires look great.  I'm curious to hear your opinion on how those Firehawks handle the road.
« Reply #9 on: March 02, 2012 - 01:26:33 PM »
 I have those same tires and sizes on my car, and a 455 Powered Buick Regal. They are by no means an "ultimate" handling tire but best bang for the buck IMO?  10X better than the BFG radial T/A "hockey pucks" IMO   :2cents:
« Reply #10 on: March 02, 2012 - 01:29:20 PM »
Thems is what I will eventually replace my hockeypucks with!
Offline ChallengerHK
« Reply #11 on: March 02, 2012 - 03:07:51 PM »
That's a great look.
- Han Solo, Star Wars
Offline Road_Runner
« Reply #12 on: March 04, 2012 - 02:58:02 PM »
Did you check/repack/replace your wheel bearings recently?  If not, you probably want to.  Ticking that gets worse with larger meatier wheels & tires could end badly if left to itself...
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Ford.P51
« Reply #13 on: March 05, 2012 - 01:03:38 PM »
It turned that the outer brake pad wasn't really seated in the caliper very well. With brakes off it was slapping the caliper, making the "tack" sound. The rotor must have a very slight warp in it or something. Anyhow, repositioned the pad and the sound is gone.
Gotta check the lights and take her in for an inspection. It'll be nice to finally get her on the road again! Thanks for all the suggestions everone.
1972 Challenger
Offline IMNCARN82
  • LeDZeP
« Reply #14 on: March 10, 2012 - 05:02:12 PM »
WOW THAT LOOKS GREAT!! :clapping:   I LOVE IT!!! :cooldancing:     Really changes the whole look! Meaner with class and style. The darker color spokes and that blue is amazing. At first it looked photochopped er somethin' :clueless:   Nice pix too. That's one of my new favorite cars around here!  POST MORE PIX OF THAT THING!!! :droolingbounce:     I'm seriously considering painting the spokes of my wheels now. The gunmetal iz perfect. R/T
SWEEEEEEEEEeeeeeeeeeeeeeeeetttttttttt :bigsmile:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
