Author Topic: Streeing box removal and stripped header bolts  (Read 989 times)
Offline ff6849
« on: March 03, 2012 - 11:03:59 AM »
I finally got the rebuilt 440 in the Cuda  running after 6 years of sitting, runs great, but the steering box leaks like a sieve, now to make matters worse trying to get this out is a PITA , in the process I have two stripped TTI  header bolts (head of the bolt) and how in the hell do I get these bolts out now, I almost to point of cutting the header off with saw-all to get a set of vise grip on the bolt and just replace the header.  :banghead: :pullinghair: :stomp: Any advice before I get this extreme please help a novice........and I still have to get the f%^$$ing  :swear: box out ......it's going to feel firm for a stage III rebuilt.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline ChallengerHK
- Han Solo, Star Wars
Re: Streeing box removal and stripped header bolts
« Reply #2 on: March 03, 2012 - 02:31:34 PM »
I swear by these things:
http://www.google.com/products/catalog?hl=en&sugexp=eqn,fixedpos%3Dfalse,boost_normal%3D20,boost_high%3D1000&gs_nf=1&cp=8&gs_id=1f&xhr=t&q=bolt+remover&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1024&bih=639&um=1&ie=UTF-8&tbm=shop&cid=7657507029202909500&sa=X&ei=vkJST6rcAq-00QGQ49nHDQ&sqi=2&ved=0CFYQ8wIwAg
When I've had a bolt that's completely rounded I've hosed it in Liquid Wrench, then I'll take the next smaller bolt remover and hammer it onto the bolt head.
I have those, they work great, got mine at Sears. I used them to get the antitheft lugs off when I first got my car.( no key) I don't know if there would be enough room near a header for these though? :dunno:   I'm with David,,,hammer on a metric socket or what ever fits?
Offline dutch
« Reply #3 on: March 03, 2012 - 05:53:28 PM »
I`ve had a similar problem years ago. I did what Brad says,  hammer on a smaller ( maybe metric?)  socket ,  but I heated the bolt head first with a small torch... white hot.
then hit the socket in place and let it cool down.  This way you make a nice fit.  It the bolt is hot enough you wont need too much force to get it on, just speed.
*** Bart ***
Offline ff6849
« Reply #4 on: March 03, 2012 - 08:37:02 PM »
Update:
Took a Dremel Multi-Max Oscillating Tool and was able to cut the head of the bolt, the one behind the header tube (couldn't get a socket on that one) with several blade changes, got a set of grip tite round bolt sockets which worked great....unbolted the motor mounts and jacked up  the motor and pesto steering box on the ground...thanks for your suggestions especially the rounded nut socket recommendation, that did the trick
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
Offline dutch
« Reply #5 on: March 04, 2012 - 01:58:49 AM »
how far did you throw the box...  :stomp: :bigsmile:
*** Bart ***
Offline ff6849
« Reply #6 on: March 04, 2012 - 02:25:01 AM »
It almost made to feel firm, should save me a little on shipping......... :money:
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
« Reply #7 on: March 04, 2012 - 08:33:03 AM »
LOL
