Author Topic: re-installing a Steering box and connecting steering linkage  (Read 1008 times)
Offline ff6849
« on: March 04, 2012 - 01:49:28 AM »
I finally got the steering box out of the Cuda, and its getting sent off to feel firm for a stage III rebuilt. Now, how do I put it back in. I am mostly concern with the proper alignment of the steering wheel, steering linkage, and the ailment of the pitman arm on reinstalling it.  This is my first build and I am somewhat of novice, well the truth is I am novice.  :clueless:
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Re: re-installing a Steering box and connecting steering linkage
« Reply #1 on: March 04, 2012 - 08:29:40 AM »
if all you did was pull the center link off the pitman arn  & remove the pitman arm from the steering box & remove the column ...... then the pitman arm can only go back on one way  as it has 4 master splines &  the coupler on the column is also master splined . if you removed the column from the coupler then you have a 505/50 chance of reassembling it correctly
Offline halle09
« Reply #2 on: August 12, 2014 - 08:32:41 PM »
sorry for a new post on this old topic but i am about to install a firm feel box as ell i am returning my core when i put the new one it. do i need any special tools to get the old one out and how do i do it in the first place haha?
