275/40 17 on a 9 inch rim without spring relo???
Author Topic: 275/40 17 on a 9 inch rim without spring relo???  (Read 1398 times)
Offline kowalski
  • Challenger=SCCA Trans Am Homologation Special
« on: January 30, 2005 - 10:50:45 PM »
Is it possible to fit 275/40 on all 4 corners with 9 inch rims without spring relo kit? 5 inch backspace on the rims. wil it work with a rolled fender lip and a spacer?l
« Last Edit: January 31, 2005 - 10:26:29 AM by kowalski »
1970 318 bored .060 over edelbrock performer intake ported and polished 360 J heads 2.02 intake 1.60 exhaust double springs carter hi cap fuel pump edelbrock victor series water pump MSD 6AL flotech headers
Re: 275/40 17 on a 9 inch rim without spring relo???
« Reply #1 on: January 31, 2005 - 12:51:29 AM »
I believe you wil have a problem with the front tire rubbing the frame rail in front on tight turns
Offline kowalski
« Reply #2 on: January 31, 2005 - 07:23:00 AM »
if i rolled the fender lip and used a thin spacer would that work?  And you think I will be ok in back?
« Last Edit: January 31, 2005 - 10:28:16 AM by kowalski »
Offline challenger500
« Reply #3 on: January 31, 2005 - 11:10:41 AM »
Kowalski man,
rear is ok with 5" backspacing w/275's w/o fender mods or relo kit. just throw them in and give it a pedal  :grinyes:
Front will be problem with 275, like CP said the inner will rub. depending on the ride height also the fender opening will rub when you turn.. so smaller tire in front, OR heavy high riser  :grinno:
Dementia already from the year...mmmm ???
Offline kowalski
« Reply #4 on: January 31, 2005 - 12:36:48 PM »
what do u mean by a heavy high riser?
« Reply #5 on: January 31, 2005 - 02:15:49 PM »
well, if ya raise the front end high ... but that's not gonna be a good thing in a highway over 80mph, grabs some air under and you'll "float"  :nono:
