Author Topic: installing tach for standard dash  (Read 6956 times)
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« on: March 05, 2012 - 01:45:30 AM »
How hard would it be to install a tach into a standard dash?  I saw a tach for $200 that goes into the factory opening.  Can it be installed without tearing apart the dash?   I'm just thinking out loud.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline ajantics
    • Yeah......Im a drummer!
Re: installing tach for standard dash
« Reply #1 on: March 05, 2012 - 02:06:05 AM »
I got one from redline gauge works about a month ago but I have not had a chance to install it yet!
http://www.redlinegaugeworks.com/prodebody.asp
70 Barracuda
73 'Cuda
2003 Dodge Ram 3/4ton
2009 G37s
Offline TinCuda
    • 'Cuda
« Reply #2 on: March 05, 2012 - 02:21:08 AM »
The instrument cluster has to come out.  I installed mine when I pulled the whole dash out to replace my dash pad.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline black71
  • eph 6:12
« Reply #3 on: March 11, 2012 - 08:14:22 PM »
How do u like it? Been considering going this route
Offline TinCuda
    • 'Cuda
« Reply #4 on: March 11, 2012 - 09:06:31 PM »
My dash is a work in progress so I don't have it hooked up yet.  It looks good.  I think if someone didn't know what they where looking at would think that it belongs there.  The way the dash is, the tach will only fit in one spot.  Mine had a blanking plate there but it is where an optional clock would go.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline highberg
« Reply #5 on: March 11, 2012 - 09:30:59 PM »
I put one in. Looks good compared to the blank but I find it really off to the side for a tach. I wanted a clean factory look and didn't want to do the rally dash option for about 1k. You can put it in from behind if you want to try. 2 phillips screws on the back and the blank comes out. Screw the new on in and hook up. Instrument panel is really easy to pull though, dropping the steering wheel is the biggest part of the job.
Classic Restorations
1973 Cuda 496 Stroker NOS
1971 440+6 4 Speed Roadrunner
1961 Shortbox Fleetside D100
1970 Dodge Dude 383 Auto
2009 SRT8 Challenger 6 Speed
Offline 74challenger03
« Reply #6 on: March 11, 2012 - 10:32:31 PM »
LOVE THE TACK , why does the alt gauge show charging with the car off?
Offline TinCuda
    • 'Cuda
« Reply #7 on: March 11, 2012 - 11:24:22 PM »
I guess when I said earlier that my dash was a work in progress, I didn't realize that I needed to spell out that what I meant was that not everything was in tip top working order...
But thanks for pointing that out for everyone.  LOL  I still have some gremlins to chase out.
« Last Edit: March 12, 2012 - 10:30:05 AM by TinCuda »
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline black71
  • eph 6:12
« Reply #8 on: March 15, 2012 - 12:30:28 AM »
How does the needle shape and font coincide with the factory gauges? Is it a close match
Offline TinCuda
    • 'Cuda
« Reply #9 on: March 15, 2012 - 02:39:28 AM »
I think the font and needle look good.  This tachometer was made specifically for an E-body non-rallye dash.
 The problems I have with it is coughing up the 200 bucks to buy it.
And the placement on the dash.   It is the only place it will go without heavily modifying your dash frame.   I think the tach should be next to your speedometer.   Oh well.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline Finoke
« Reply #10 on: April 26, 2013 - 11:37:13 AM »
I installed mine next to the speedo but lost the wiring diagram to hook it up. The dash has been out of the car for about 6 years. Any idea where to find the wiring diagram to hook it up  :bigsmile:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: April 26, 2013 - 01:07:22 PM »
Finoke
I can post that up for ya but you have to answer 2 questions first.
1) Do you have a Barracuda or Cuda? There is a reason based on your switch panel.
2) What's the switch you installed in the rear defog position?
Cheers,
Bryan
Offline Katfish
  • 70 Challenger
« Reply #12 on: April 26, 2013 - 02:36:56 PM »
Seems much better right next to the speedo, IMO
Offline Finoke
« Reply #13 on: April 26, 2013 - 02:58:09 PM »
Finoke
Cheers,
Bryan
Hi Bryan,
I've got a 70 Barracuda. I cut the gauge panel to insert the tach. Then I moved the other guages over, leaving the alt gauge where it was. I mounted the temp gauge in the plastic insert that was in the blank pod.
Funny you mentioned the extra switch that was added. That after market switch was in the car when I got it, but not hooked up to anything.  :bigsmile: I left it there since its better than seeing a hole. I might be able to use someday.
Yes, if you have directions on how to hook up the tach it would be great.
thanks
Tom
Offline TinCuda
    • 'Cuda
« Reply #14 on: April 26, 2013 - 03:17:21 PM »
Hook the red wire to power, black to ground, and the green wire to the Negative post of your ignition coil.  That's it.
« Last Edit: April 26, 2013 - 03:22:54 PM by TinCuda »
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
