Author Topic: 1970 cuda quarter and tail panel help !!!!!  (Read 1237 times)
Offline philze
« on: March 05, 2012 - 12:59:52 PM »
   I need a little advice on a few little problems I am having on my new 1/4 panel metal fitting.
First off both sides of the trunk ext have a got of about 1/4 inch gap at the trunk pan when they are put in place against the wheel well opening.
 I had a set of older goodmark ext that didn't match the wheel well so I ordered a set of AMD ext. They fill the well great but they are only 6 inchs wide while the original and the goodmarks are 6 1/4. I haven't test fitted the rear valance yet but I don't think they will pull in that much because they are on the original rear crossmember extension already.
 My second problem is the markerlights. They both hit the trunk ext.on the back corner. I can't get the 1/4 any higher or the trunk ext any lower. I have a 11 1/4 inches from my trunk floor to the top of my taillight panel and everything else seems to fix fine.  the rear is all level and square and the tailpanel to 1/4 panel gap is nice as is the door gaps. The trunk pan and 1/4 panels are all new AMD the tail and gutters are all original to the car. Could someone see what they have for a hieght on the tailpanel although I don't know how I coud raise it without messing up the fit in a different spot.
Offline Jocigar
Re: 1970 cuda quarter and tail panel help !!!!!
« Reply #1 on: March 05, 2012 - 09:03:35 PM »
i measured mine at 11 1/2"  all stock panels.
what do you mean by hit ?  the side marker hole being lower than the extension?  Let me know if you need other measurements
