Author Topic: Data plate help  (Read 10845 times)
Offline Crownvic55
Data plate help
« on: March 06, 2012 - 05:51:14 PM »
I bought a plymouth Barracuda awhile back and never really looked into the data plate much. Can anyone tell me what the important numbers are on the plate. I took it off the fender on the inside under the hood. It matches the vin on the dashboard as you look at it under the windshield from the outside so I know its the right one. Also I have not done any research on this car yet and don't really know much about the plymouth line. I bought it from a Pizza guy in AL and he got it from a guy from Norway going through flight school here in the US. He got tired of it and wanted a newer mustang so I bought it off him before he moved. It was running good when he parked it a long long time ago. Looks like it will be a cool Sunday driver when I get it cleaned up. Any help would be appreciated.
Crownvic55
Offline Jamiez
  • Retro
Re: Data plate help
« Reply #1 on: March 06, 2012 - 05:53:19 PM »
The plate you are referring to is known as a "Fender Tag" it has a lot of information on the options the car was manufactured with.  If you post it here I'm sure you can get some help translating it.
Offline Crownvic55
Re: Data plate help
« Reply #2 on: March 06, 2012 - 06:15:45 PM »
The numbers are in 5 rows and 3 OR 4 digits each
(1) N85, N97, R11, V6X, END
(2) N45, M21,M25, N31, M88, N4 (The N on the first digit in this line is hard to make out due to the hole in the data plate from the scew that held it to the fender. It may be an M or something else.
(3) EK2, AO4, A62, C55, G34, J25
(4) EK2, H6X9, OOU, LO5, 135338
(5) E87, D32, BS23, VOE, 127592
Some of the data is hard to make out due to the paint chipped out etc..
Also some may be zero's and not the letter O. It's hard to tell.
Crownvic55
« Last Edit: March 06, 2012 - 06:20:58 PM by Crownvic55 »
Offline Jamiez
  • Retro
Re: Data plate help
« Reply #3 on: March 06, 2012 - 06:48:27 PM »
That is a fairly desirable engine code.  As a V code that would be a 440-6 pack car.  It's also a BS which makes it a true 'Cuda (as opposed to a Barracuda or Grand Coupe)
I used the following site to do a quick decode.
http://www.stockmopar.com/mopar-fender-tag-decoder.php
E87   440-6 Barrel High Preformance
D32   H-D A-727 TorqueFlite Trans / Some Years A-998
BS23
B = Plymouth Barracuda
S = Special
23 = 2 Door Hardtop
VOE
V = 440 390HP 3-2BBL 8 CYL
0 = 1970
E = Los Angeles, CA, USA
127592   Sequence Number '127592'
EK2   Paint Code: Go-Mango / Vitamin C Orange
H6X9
Trim Grade/Style/Color
H = High
6 = Vinyl Bucket Seats
X9 = Black
000   Upper Door Frame: Full Door Panel
105   Date Built: 1 / 05 / 1970
135338   Order Number: 135338
EK2   Roof Type OR Color:  Go-Mango / Vitamin C Orange
A04   Basic (Radio) Group
A62   Rallye Instrument Cluster
C55   Bucket Seats
G34   Left Hand Outside Mirror - Manual / Painted / Raci
J25   3 Speed Variable Wipers
N45   High Capacity Fan
M21   Roof Drip Rail Moldings
M25   Wide Sill Molding
N31   opt compress ratio
M88   Quater Panel Tape Treatment
N4   Unknown At This Time
N85   Tachometer
N97   Noise Reduction Package
R11   Music Master Radio AM
V6X   Black Longitude Sports Stripe
END   End of Codes
The bold codes I am not sure of.  I know the code you have is LOS is the date code where the first digit is the month (1-9,A,B,C,D) the second is the year (0=1970) and the last indicates the day.  My guess is 105
N4 is missing a digit.  I'm sure some of the better code readers will be along
Offline Crownvic55
Re: Data plate help
« Reply #4 on: March 06, 2012 - 07:05:47 PM »
Thanks for all the info. The last one on the second line may be N41. What is a Quarter panal tape treatment and Opt compress ratio? Is that a type of Quarter panel sealer and different compression ratio for the engine?
Thanks again for the work you did in putting the numbers together.
Crownvic55
Offline CarelianCuda
    • http://bot.fi/3gu
Re: Data plate help
« Reply #5 on: March 06, 2012 - 07:06:01 PM »
You just buy real EK2 Vitamin C orange 'cuda 440-6 column shift auto without looking data much? :eek7: Lucky you :thumbsup:
You can see most codes on here: http://www.mopar1.us/6971codes.html
Check tag again, there is some issues, like N4* is N41, N31 is M31, N45 is not N42 in this case and not that place, 00U is 000, Date code L05 might be example 105 = Janyary 5th. 1970
Date code:  First month (Starting august 1969: 8,9,A,B,C,1,2,3......) and then day of month 01 to 31.
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
    • http://bot.fi/3gu
Re: Data plate help
« Reply #6 on: March 06, 2012 - 07:08:47 PM »
Quarter panel tape in this case : V6X = Black hockey stick stripe with 440 call outs
Edit: you meant M88 which is tail light surround moldings.
-Juha
« Last Edit: March 06, 2012 - 07:22:26 PM by CarelianCuda »
Offline Crownvic55
Re: Data plate help
« Reply #7 on: March 06, 2012 - 07:20:04 PM »
The column shifter was replaced by a B and M speed shift. The right column must still be in the car because I can see where the shifter pndr window has been painted over. Thanks for the decoder page. I looked up N41. Looks like duel exhaust without tips???
Crownvic55
« Last Edit: March 06, 2012 - 07:32:01 PM by Crownvic55 »
Offline Talkwrench
  • Perth, Western Australia
Re: Data plate help
« Reply #8 on: March 06, 2012 - 07:31:45 PM »
 :useless:  so the next question is.... Do you own a '55 Crown Victoria as well ?? If so hello from a fellow Y blocker..  :wave:
"Came too close to dying to stop living now!"
Offline Crownvic55
Re: Data plate help
« Reply #9 on: March 06, 2012 - 07:43:38 PM »
My first car was a 55 Crownvic I bought it for 300.00 bucks back in 77 from a alleyway in Jefferson City Mo. My Dad helped me fix it up and we painted it Pink and Black.  Sorry I have no pics of the Plymouth. It is actually covered up in my barn back in the US. I took the engine out and it is on a stand ready to take apart and repaint. I put some new covers on it and decided I might as well clean it up so it looks better in the engine bay. I am in Germany right now and I had the data plate in my lock box and just got curious about what the numbers were. I bought the car a long time ago but have been deployed or out of the country just about every year since I got it in AL. Looks like I will have my next project now that I am finally returning to the US for good. I'll see if I can dig up some pics for ya. I will need to scan them since they were all taken with traditional film cameras.
Crownvic55
    • http://bot.fi/3gu
Re: Data plate help
« Reply #10 on: March 06, 2012 - 07:54:54 PM »
Another night owl :bigsmile:
I think at i go sleeping right now, we have one hour more on clock than you have :banghead:
Offline KFD
  • I'm big in Japan!
  • Owner, sweet pistolgrip shift handle.
    • Kelly's Cars
Re: Data plate help
« Reply #11 on: March 07, 2012 - 01:28:53 AM »
Hey Fellas, did we forget that Los Angeles didn't produce six pack cars?  :nono:
It has all the legit 'Cuda stuff on it, but I am betting that is a mistranslated vin code...
KFD
Aprilia RSV 1000. Ask the man who owns one!
Offline Cuda Cody
  • Vancouver, WA
Re: Data plate help
« Reply #12 on: March 07, 2012 - 02:17:53 AM »
Yes, they did produce 440 6 packs.  No Hemi's or T/A's.
KFD
Offline GranCuda1970
Re: Data plate help
« Reply #13 on: March 07, 2012 - 02:40:27 AM »
Yep, and although not a 440 6pack car mine has the GOE instead of the VOE the E is   L.A. California. Prolly don,t have abuild sheet.
Offline Crownvic55
Re: Data plate help
« Reply #14 on: March 07, 2012 - 03:41:26 AM »
What is a build sheet?
Crownvic55
