yes you can ignore or remove the 5 pin plug for the ECU , the ballast & connectors can also be removed , you need to connect the small red trigger wire for the MSD to the Brown & Blue wires at the ballast to get it to start & run .
the wires for the Alt ran along the valve cover , do not lay them on the manifold or they will melt & short
