Refinishing Interior Plastic???
Author Topic: Refinishing Interior Plastic???  (Read 2026 times)
Offline 2000gt
« on: February 01, 2005 - 07:04:21 PM »
Hey guys, I am ordering new autometer gauges to put in my non-ralleye dash.  However, I want to refinish the plastic first as it is old and crappy looking.  Any suggestions, ie paint type, technique, etc?  Or does anyone make a reproduction one? Thanks, Tyler
« Last Edit: February 01, 2005 - 07:17:11 PM by 2000gt »
Offline bluecuda
Re: Refinishing Interior Plastic???
« Reply #1 on: February 01, 2005 - 07:23:14 PM »
Check into dyeing your parts. It's easy,no need to thin/reduce the dye. Spray it right out of  the gun. I did this on my kick panels and they turned out nice (if I may say so.)
A good paint supply store is ths answer to your success.
Offline 2000gt
« Reply #2 on: February 01, 2005 - 07:26:54 PM »
Yeah, but I think my problem will be that the plastic has gone knid of brittle and flaky in places leaving scratches, it there any way to sand this of and start with new material?
Offline bluecuda
« Reply #3 on: February 01, 2005 - 07:31:49 PM »
I blasted my parts first in a blast cabinet to remove the flaking. :ack:
Sound scary but it works.
kudakidd
« Reply #4 on: February 01, 2005 - 07:52:09 PM »
SEM products makes a kit for preping the plastic and make what most consider to be the best plastic dyes. Go to your auto paint store, not Pimp Boys!
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #5 on: February 02, 2005 - 08:52:27 AM »
Here is what I did a couple weekends ago.  I started with a standard dash, cut out a poster board template of the front dimension, and then did a layout on the template of where I wanted my guages.  After the template was completed, I traced the template on a piece of thin panel board and cut everything out.  Did a test fit of the gauges in the board, did some fine tuning, drilled holes for the indicator lights, and did a light sanding.   I then had to cut all the gauge pods from the original dash leaving about 1/2 inch lip on the front so I could attach the panel board to the dash panel using some small bolts and nuts.  At that point I used some Tiger Hair (fiber glass that works like bondo) on the entire new dash panel assembly.  Sanded it, moved to bondo to fill in some of the larger imperfection, sanded, moved to primer, sanded, and repeated as nessessary. Finally I painted and installed the guages.  I was happy with the results, but may do some more finish work and use a quality automotive paint to get a better show quality.  I also would like to try to take the hump off that I left from the original speedo.  I don't think it would be much work and would still be very rigid.
[attachment deleted by admin]
« Last Edit: February 02, 2005 - 12:28:57 PM by HemiDog »
Offline dilligaf
    • Willcraft Technologies Ltd.
« Reply #6 on: February 02, 2005 - 10:36:18 AM »
HemiDog,
Your tag line says it all "get er done"
Looks really good.
Dan
2 1974 'Cuda's
1 1973 Challenger
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #7 on: February 02, 2005 - 01:12:26 PM »
HemiDog, that turned out great looking!  I never would have though of that.
2000GT, we used the SEM products to clean and dye all of our panels, seat backs, console, etc.  The SEM stuff works great.  There were a couple of places where I wet sanded to get rid of some scratches, but not deep enough to lose the texture.
Offline Street_Challenged73
« Reply #8 on: February 03, 2005 - 11:43:27 AM »
Also, if you have any chips in the plastic, try a skim of JB weld.  Here's what I did to my ac/heater control bezel and radio bezel...Now they just need a skim coat of SEM's black dye and it'll be all good. :thumbs:
Offline 74chall
  • Mopar or No Car
« Reply #9 on: February 04, 2005 - 02:15:22 PM »
Let me tell you something. I found the best paint for plastic i ever used in my life at WAL MART. Yes wal-mart! .Its made by Krylon and its called FUSION "for plastic". Get it in satin black and your plastic pieces look like new! When it was done drying i purposely tried scratching it off and it would not come off. I was impressed! It doesnt ruin the textured look either! Im telling ya'll deff. worth giving it a try!
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #10 on: February 04, 2005 - 06:54:44 PM »
You can wet or dry sand the plastic but you will lose any texture it has.You can get some texture back by spraying a couple coats very "dry" and then a few more coats but it probably won`t look correct.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Grancoupe
« Reply #11 on: February 04, 2005 - 09:00:49 PM »
I've seen wrinkle paint used for texture. It varies in texture depending on how you spray it on. A little practice and you might get what your looking for.
Offline miketyler
    • www.miketyler.net
« Reply #12 on: February 28, 2005 - 12:18:14 PM »
Quote
74chall - I have heard of that stuff; is supposed to chemically bond with certain plastics. Can you see any halos or dry spots where you can tell it was rattlle canned?
I have only seen a few rattle can products that left a perfectly uniform pattern with NO derivations in gloss. One is Rustoleum's "stainless steel". Helluva great product, makes your metal parts look like they were freshly bead blasted. Hard to find it, I was mail ordering it until I found some at the Home Depot in my area
« Last Edit: February 28, 2005 - 03:04:50 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline 74chall
  • Mopar or No Car
« Reply #13 on: February 28, 2005 - 04:38:44 PM »
cant tell it was spray bombed. looks like the pieces are brand new. I was literally shocked!
 :eekbig:
Offline onebadhemi
« Reply #14 on: March 11, 2005 - 04:09:22 PM »
74 chall........thanks for the tip .........now  :driving: I'm off to walmart :guitar:
1970 R/T Challenger
1971 Pro street"HEMI" Challenger
2003 V-10 Ram 2500 Q/C
2006 Charger R/T
