Author Topic: can i fit a 15X10" wheel in the back?  (Read 4984 times)
Offline The4ork
« on: March 14, 2012 - 09:13:52 AM »
will it fit? with a 4" backspacing on a stock rear, lifted a little with some air shocks? if so what size tire would i be able to run?
Offline R/T hedkace
Re: can i fit a 15X10" wheel in the back?
« Reply #1 on: March 14, 2012 - 09:38:52 AM »
What kind of car?  :dunno:
Jeff
    Defending the Earth from "uptight" mods!!   an endless crusade..........
1970 Dodge Challenger R/T 440 4speed Dana
1970 Dodge Super Bee
1969 Barracuda
 Massachusetts
Offline Road_Runner
« Reply #2 on: March 14, 2012 - 05:47:55 PM »
Some folks do run 10" on back, most with at least 4.5" backspacing and 1" relocated springs using the Dr. Diff kit.  I ran 10" rims on my Roadrunner, but the airshocks kept the tire sidewall clear of the fender lip or it would rub.  Tire height is also going to matter, if the tire diameter is small enough you might clear the fender, but not sure how that would look.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #3 on: March 15, 2012 - 09:46:23 AM »
Shades of the 70's, man. Sure it can be done, but you have to give up suspension travel to accomplish it in this manner. That means the shock crossmember takes a beating to keep the tires out of the fender lip. The method posted by road runner is the better approach of avoiding interference.
Offline The4ork
« Reply #4 on: March 15, 2012 - 10:40:40 PM »
i saw a camero today with a 275 rear wheel, not sure how wide the rim was but what would be a good width for a rim to run that size of a tire?
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: March 15, 2012 - 10:51:48 PM »
I think the majority of the guys running a 275 rear tire are using 15x8 with the stock suspension on the E-bodies.
Offline Road_Runner
« Reply #6 on: March 16, 2012 - 11:15:00 AM »
I'm running 275/60x15 BFG TA's on 15x8 rallyes on the back of my Barracuda and they look & fit great with no airshocks.  Honestly, with that size tire the 8" rim is going to look a lot better than with a 10" rim.  I'd go to a wider profile 55 or lower series of tire to go with a 10" wide rim because the 275/60's are already plenty tall for the car. I may go back to 10" rims on the back of the Roadrunner but that's because I'm looking at a 600+ HP stroker motor & figure I need the extra tire patch for traction.
Later, Jim
