Author Topic: Spring to tire clearance  (Read 932 times)
« on: March 14, 2012 - 11:16:11 PM »
How much space between the rear tire and the leaf spring would be enough to be safe? 1/4", 1/2" 1"?  :dunno:
The tire is a 315/35/17 and I looking at about 3/8" clearance at the moment.
Re: Spring to tire clearance
« Reply #1 on: March 14, 2012 - 11:19:43 PM »
I think I'd be looking for 3/4" at least? :2cents:
« Reply #2 on: March 14, 2012 - 11:24:57 PM »
3/8 should be fine , unless you are corner near 1 g the sidewall deflection that high up will be minimal
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: March 15, 2012 - 01:31:50 AM »
3/8ths should be plenty, that size tire has barely any sidewall to flex anyway
« Reply #4 on: March 15, 2012 - 09:44:03 AM »
I've run as low as 1/4" without contact. Larger, softer sidewall tires like drag slicks may be at greater risk of contact than more rigid street tires.
Typically what I've seen is compliance in the suspension bushings allows the whole rear assembly to side load and move as a unit over the sidewall deflecting that high up off the ground.
« Reply #5 on: March 15, 2012 - 10:39:33 PM »
Thanks for the feedback guys  :cheers:
