Author Topic: Distributor install help  (Read 674 times)
Offline Justins72
« on: March 15, 2012 - 01:24:54 PM »
Im replacing my the distributor to an MSD pro billet one. When I removed the old one I had the rotor lined up exactly on the number 7 cylinder of the Firing order. When I installed the new one it now lines up on the number 2 cylinder of the Firing order. Can I just make the #2 on the new cap of the MSD number #7 and work my way around following the correct Firing order? Also it says in the instructions that if it doesn't line up that I may need to rotate the oil pump shaft. When I looked down the hole its meshed with the camshaft and looks as if the camshaft would need to be slid forward in order to rotate the distributor gear.
Offline 72cudamaan
Re: Distributor install help
« Reply #1 on: March 15, 2012 - 03:32:53 PM »
That would work, but it would be better to put the engine on #1 compression stroke. That way in the future you don't wonder what's going on.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: March 15, 2012 - 03:44:51 PM »
:iagree:
You actually lift the gear you see and then turn it and then let it spiral back down into place.
You can re-arrange the plug wires as you suggest and it will work, but I would index the gear instead.  :2cents:
Offline Justins72
« Reply #3 on: March 15, 2012 - 05:26:09 PM »
Alright, I wasnt sure if that gear would just come out. Any tips on getting the gear out?
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #4 on: March 15, 2012 - 07:28:15 PM »
a good telescopic magnet works for me,,sometimes you may need a long screwdriver to help move it back and forth  untill it frees up
72rtchallenger
what happens in the garage
stays in the garage
Offline jimynick
« Reply #5 on: March 15, 2012 - 09:06:08 PM »
You could also take an old metal clothes hanger and cut off a chunk, bend a small hook on one end and slip it under the edge of the gear to help pull it up. Make sure it goes ALL the way back down as it re-merges the hex drive in the oil pump.  :2cents:
« Reply #6 on: March 15, 2012 - 09:56:22 PM »
I usually just wind it up out of the cam with a large screwdriver
