70-’74 E-Body Dash Pad Removal and Replacement
Author Topic: 70-’74 E-Body Dash Pad Removal and Replacement  (Read 10495 times)
Offline TorOrange
« on: March 15, 2012 - 01:37:18 PM »
Thought this could be helpful to some.
http://v8tvshow.com/content/view/717/1/
WANTED 71 cuda / barracuda project. Prefer Black but open.
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: 70-’74 E-Body Dash Pad Removal and Replacement
« Reply #1 on: March 15, 2012 - 01:41:37 PM »
Awesome!  Thanks for posting.
God I love those red interiors!
Offline TorOrange
« Reply #2 on: March 15, 2012 - 01:47:37 PM »
 :2thumbs:
I know every time I see red Interior I think 'Cuda Hunter
Offline stsom
« Reply #3 on: March 15, 2012 - 04:10:12 PM »
ThankU! Just what I needed!    :bananasmi   :ylsuper:
http://www.bilfrik.com For us that never stopped playing with cars
Offline spamtank
« Reply #4 on: March 10, 2013 - 04:19:09 PM »
For what it's worth, here's the tool I used for removal of the bolts from the defroster vents.
Flexible shaft with a 3/8" nut driver.  From all the discussions, I thought this was going to be the hardest part.  Turned out to be a piece of cake.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline stsom
« Reply #5 on: March 10, 2013 - 05:06:24 PM »
Used quite a lot of time changing the speedo on my Cuda today... Whish I had seen this page first.... :thumbsup:
Offline Katfish
  • 70 Challenger
« Reply #6 on: March 10, 2013 - 05:56:12 PM »
Been awhile since  I did this, but wasn't planning on removing the metal frame.
Was always able to remove and reinstall the pad in the car.
I guess if you're doing other work, if not it seems like extra effort.
I always remove the steering wheel also to get it out of the way.
Offline blown motor
« Reply #7 on: March 10, 2013 - 11:08:31 PM »
Just got a new dashpad on Friday. The timing of this article is perfect. Thanks TorOrange.
Offline anlauto
« Reply #8 on: March 10, 2013 - 11:09:52 PM »
That's the most Bass-ackwards article I've ever seen :screwy: Who ever wrote that are idiots.... :2cents:
« Reply #9 on: March 11, 2013 - 10:36:01 AM »
Alan,  We would love to have your article on removing this.   I'm sure your experience would simplify the process.   :popcorn: :popcorn: :popcorn: :popcorn: :popcorn:
Offline anlauto
« Reply #10 on: March 11, 2013 - 12:16:22 PM »
Sorry I never really published an article. :stomp:
Here's what I see wrong with this article, unless they're charging the customer by the hour....
1) Why remove the pad from the frame in the car, then remove the frame ?  :banghead:
2) Why re-install the frame/pad in the car then re-assembly the rest of the dash in the car ?
  :pullinghair:
I've done about 20 E Body dash pads recently. The trick is to remove the dash assembly as a whole, restore it, then re-install it as a whole.
Here are 26 easy steps:
1)Open Hood
1.5) Dis-connect battery
2)Remove four plugged wire harnesses from bulk head
3)Remove two nuts holding bulkhead in place
4)Open doors
5)Remove A pillar trim and associated trim
6)Remove Kick Panels and associated trim
7)Unplug both door jamb light switches
8)Unplug E Brake warning wire
9)Unplug tail light harness
10)Unplug dimmer Switch
11)Reach up and unplug heater box
12)Unplug console light
13)Disconnect antenna
14)At the heater control, disconnect both heater cables
15)Unplug both steering column harnesses
16)Unplug brake pedal switch, both wires
17)Undo both vent cables and let them hang
18)Remove 3 steering column bolts at firewall
19)Remove to nuts on steering column at the dash
20)Lower column and allow to hang
21)Remove 4 bolts at windshield using a 1/4 drive flex
22)Remove 2 bolts at door pillars
23) Disconnect speedometer cable.
24)Prepare for a heavy dash to fall on your lap
25)Yell to wife for help
26) Have a cold beer, you're done
Offline Katfish
  • 70 Challenger
« Reply #11 on: March 11, 2013 - 05:43:05 PM »
If you're only replacing the pad, why even remove the metal frame?
