Author Topic: Electrical questions..mystery wires.😉  (Read 743 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: March 17, 2012 - 09:56:32 PM »
A few questions.
I have these mysterious electrical wires left from my build, and I can't seem to remember where they went, with the exception of the A/C drier wire harness.
A/C drier connector. I need a reference for what the other side looks like, as well as what it attaches to
Is this to the column courtesy light?
What does it connect to?
What is it and where does it go?
It's quite obvious I am missing a connector here. What does the other end connect to? What connectors do I need?
Thanks in advance for all of your help!
Dan
Offline Jamiez
  • Retro
Re: Electrical questions..mystery wires.😉
« Reply #1 on: March 17, 2012 - 10:12:06 PM »
That last one looks like the wires for the center speaker?  If they are, I don't think you are missing a connector, I believe that just slips over a post on the speaker
« Reply #2 on: March 18, 2012 - 07:28:59 PM »
the middle picture is the column key in ign lite , it should connect into the dome lite cicuit with a small canister which is the timer
 there should be a pressure switch on the dryer with flat button that connector will slide onto for the A/C
