Author Topic: dash pad  (Read 9711 times)
Offline 1of1
Re: dash pad
« Reply #30 on: May 26, 2012 - 01:40:20 PM »
Yes, dash is something you see and look at all the time.  Getting it right is worth the effort / expense.
Yes it is , Here is a just dash on stock metal frame Vacuum formed...They use newer glue and materials, it is a work of art and worth every bit of $900.00  :burnout:
1970 Cuda 383/335hp/4sp/V02
2006 FordGT40 Black Naked
Offline ChallengerHK
Re: dash pad
« Reply #31 on: May 26, 2012 - 02:22:18 PM »
Do you have pics of the ABS-frame pad for comparison?
- Han Solo, Star Wars
Offline 1of1
Re: dash pad
« Reply #32 on: May 26, 2012 - 07:32:36 PM »
No Sorry....it was so bad it went right back to Year One the same day....The dead give away was that is sagged when i took it out of the box and the wrap was wrinkled around all areas where it made a change in direction...Good thing Year One allows full refunds...In the cases of the dashes "You get what you payfor" no shortcuts on this one...... :wavingflag:
Offline TinCuda
    • 'Cuda
Re: dash pad
« Reply #33 on: May 27, 2012 - 06:02:05 AM »
Here is a close-up so you can see the grain.  I got mine from Dave at Roseville.
(O O [             SRT ] O O)
(O O {]{]{]||[}[}[} O O)
{||O||}
2016 Dodge Challenger Hellcat
1971 Plymouth 'Cuda 440-6
2008 Dodge Charger R/T Hemi
2015 Chrysler 200c AWD 3.6L
2000 Yamaha V-Max
Doing my part to leave a big carbon footprint!
Image Hosted by ImageShack.us
Shot at 2012-09-05
Offline 1of1
Re: dash pad
« Reply #34 on: May 27, 2012 - 12:53:48 PM »
Is that a stock metal core dash or a plastic core?
Offline TinCuda
    • 'Cuda
Re: dash pad
« Reply #35 on: May 27, 2012 - 06:21:43 PM »
original metal core.
(O O [             SRT ] O O)
{||O||}
2000 Yamaha V-Max
Shot at 2012-09-05
Offline thedarkside
Re: dash pad
« Reply #36 on: June 05, 2012 - 10:21:40 PM »
Just received mine from Roseville. It looks great but there are definitely issues with it. First and most annoying is having to drill all the holes for the speaker, ac vents, etc. Secondly having to cut out all the excess foam near the cluster. Its not too hard but IMO should be a little better produced for the insane high price. Nerve racking when you have to drill and exacto around a soft part that cost that much.
Offline thedarkside
Re: dash pad
« Reply #37 on: June 05, 2012 - 10:28:14 PM »
I guess I should expand and give some credit though. I worked with John at Roseville to get the part and I can say hands down some of the best service I have come across. Excellent communication. The trimming and drilling I think are partially the fault of some old warped parts. Its a great pad but dont expect to just assemble it with nasa precision.
Offline 1of1
Re: dash pad
« Reply #38 on: June 05, 2012 - 11:17:05 PM »
Just Dashs will give you a perrrectttt.....Dash ready to bolt on,  no trimming or fuss....worth $900.00 , but you will need a core....
Offline ragtopdodge
Re: dash pad
« Reply #39 on: June 08, 2012 - 11:35:12 AM »
I dunno; maybe for a '71-'74 pad style, JD is okay, but on '70 models, I can spot them 20' away.  WAY too puffy looking.  Doesn't look OEM at all.
I think the UR pads on a metal frame look the most OEM.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline 1of1
Re: dash pad
« Reply #40 on: June 08, 2012 - 11:50:45 AM »
Do you have a pic of the 2 so we can compare, Is the 70 pad a diff. pad than the later models? I think later they had sharper lines.....
« Last Edit: June 08, 2012 - 06:09:41 PM by 1of1 »
Offline thedarkside
Re: dash pad
« Reply #41 on: June 09, 2012 - 03:01:22 PM »
Here is the one from Roseville. UR dashpad
Offline 1of1
Re: dash pad
« Reply #42 on: June 09, 2012 - 07:18:08 PM »
Cuda 1970 and challenger dash are differant , one has stiches and the cuda does not... the Chally dash has much crisper lines, anyone have a UR pic of a 1970 cuda dash?
Re: dash pad
« Reply #43 on: June 10, 2012 - 08:57:32 PM »
I tried a JD pad & it was worse than the one we removed , the UR pad was far better in 2 builds I did but no pix with me here in Panama
