Recommendations for show quality engine paint job (stock, Hemi Orange)
Author Topic: Recommendations for show quality engine paint job (stock, Hemi Orange)  (Read 11793 times)
Offline Carlwalski
Re: Recommendations for show quality engine paint job (stock, Hemi Orange)
« Reply #15 on: July 22, 2005 - 08:11:38 PM »
Thanks not the best of photos, heres a better one.  :P
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline GoMango
« Reply #16 on: July 22, 2005 - 08:34:17 PM »
What did you use on the engine NZ? BTW, looks real good!!!
70 Challenger R/T
(Back on the road--1st time since '96)
Offline Carlwalski
« Reply #17 on: July 22, 2005 - 08:46:14 PM »
To tell you the thruth I'm not 100% sure. I bought cans (waaaay back and I didn't know any better). Then they said closer to the time they will get the proper stuff from a corwd up North. I'll find out the next time I go around, sheesh this is bad of me don't even know/remember my engine paint.  :laughing: :coffee: POR-15 I'm sure but I won't commit just yet.  :thumbs:
Oh, and thanks for the complimant.  :beer:
Offline GoMango
« Reply #18 on: July 23, 2005 - 08:20:22 AM »
I can relate to not remembering things :laughing: :wasted: :laughing:
70 Challenger R/T
Offline FY1Challenger
  • I'm a llama!
« Reply #19 on: July 27, 2005 - 01:18:52 PM »
Iwent the spray can route the first time and like you was not happy after a season of wear and tear. I pulled the engine last winter and had a body shop spray it together, following the factory method. Everything but the carb got orange paint. I talked to the PPG paint guy and followed his advice using their Concept line. He used a color library PPG has access to in order to convert the original formula to the modern day formula. He said it would hold up better in the heat of the engine bay. So far, so good. I did install an intake manifold block off style gasket to keep the paint from cooking off of the heat cross over passage under the carb, but that leads to some cold start aggrivation. If you want more info PM me and I'll get you more specifics. Yea I know... :worthless:
Offline 70Cuda
  • 70 Cuda 383 70 Challenger 440+6 71 Challenger 383
« Reply #20 on: October 06, 2005 - 08:02:06 PM »
Yeah, I would like some more info from you FY! Challenger.  How is it holding up, what was the advice, paint formula if it's any good, etc.
Offline Rare_T_A
    • Freiss Family Mopar Site
« Reply #21 on: October 13, 2005 - 04:26:08 PM »
I did bothe my RR and T/A with PPG base/clear. It hols up great and will stay glossy for ever. I have 4500 miles on the RR and it looks as shiny today as it did when I intalled it. To stop the burning intake you need to get the gaskets with the crossover block off. That is what I due, your not going to drive it in the winter anyway. Just lean out the choke and it will work great.
« Last Edit: October 13, 2005 - 05:32:19 PM by 4cruzin »
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
Offline Rare_T_A
« Reply #22 on: October 13, 2005 - 04:29:08 PM »
This is the RR's engine when I put it away a week ago. The paint is 4 years old with 4500 miles on it.
« Last Edit: October 13, 2005 - 05:33:57 PM by 4cruzin »
Fargo, N. Dak.
Offline 70Cuda
« Reply #23 on: October 13, 2005 - 09:48:34 PM »
Thanks Rare T/A.  Do you know the paint code (guessing it's V2 or EV2)?  It looks a bit bright (but very good) so maybe you used the body Hemi Orange (which I hear is a different shade).
Offline Rare_T_A
« Reply #24 on: October 14, 2005 - 08:39:57 AM »
The color I used is PPG Deltron 20000 DBC base coat. The code is DBC2186 HEMI Orange. I first primed them with DP40 I believe was the primer.
« Last Edit: October 16, 2005 - 09:59:40 PM by 4cruzin »
Fargo, N. Dak.
Offline 70Cuda
« Reply #25 on: October 16, 2005 - 09:00:03 PM »
Thanks for the codes.
Offline ntstlgl1970
  • T a c o c a t
« Reply #26 on: October 17, 2005 - 12:26:22 AM »
I used a similar paint to what Rare_T_A used, there are some pics here:
http://home.comcast.net/~andyees8/engine_paint.htm
I used PPG DP60 epoxy primer and basecoat/clearcoat, haven't done the clear coat yet, but it looks really good. I had my local paint shop match up a spray can from Mopar Performance for the street hemi orange color. I know that the spray cans are kind of a crap shoot for consistency, but I thought it looked pretty close. Kinda funny, the primer is real close to the factory light blue engine color, made it look like a low perf 383 2 bbl motor before putting the orange on.
Offline 70Cuda
« Reply #27 on: October 17, 2005 - 05:52:43 PM »
Looks good, I'd like to hear how it holds up once you get it going.
Offline moparguy01
« Reply #28 on: October 22, 2005 - 04:54:15 PM »
this is how I do it as well. but I havent ever used a base/clear on my engines. i just use single stage over epoxy. just make sure to have the engine CLEAN.
after doing my first engine this way i said i'd never go back to rattle can engine paint, and ive seen the por15 engine stuff change colors. so im not gonna touch it.
Offline jvike
  • Pro-Touring Cuda
« Reply #29 on: November 30, 2005 - 04:10:15 AM »
Does anybody know the Sikkens paintcode for Street Hemi Orange? Or how to mix it?
Hey, smilyes are back!  :clapping:
