Author Topic: Rear Anti sway bar  (Read 1122 times)
Offline Dusty1
  • Revived
Rear Anti sway bar
« on: March 19, 2012 - 08:52:33 PM »
Has anyone used an Adco rear sway bar? Is there any welding? Any problems? Thanks
Garys 1972 BS
Re: Rear Anti sway bar
« Reply #1 on: March 20, 2012 - 10:55:10 AM »
If this is a 7/8"  under axle mount bar, they are designed to bolt in, but you run the risk of tearing the screwed in mounts out of the frame rails. It would be better to weld them in.
« Reply #2 on: March 20, 2012 - 04:14:56 PM »
I've had one on for 2 years now, so only a little over 1000 miles on it. I have had no problems with it. You have to drill 2 holes in the frame on each end to fish thru a U-bolt. As HP2 said, you could beef up this area so it doesn't tear.
Offline ragtopdodge
« Reply #3 on: March 20, 2012 - 07:03:02 PM »
I like the OEM setup (which you can buy all new at Firm Feel).  Less unsprung weight.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline highberg
« Reply #4 on: March 20, 2012 - 09:07:46 PM »
I had to weld the brackets onto the rear axle. They kept working out and I was losing them. Welded them in and it works great.
Classic Restorations
1973 Cuda 496 Stroker NOS
1971 440+6 4 Speed Roadrunner
1961 Shortbox Fleetside D100
1970 Dodge Dude 383 Auto
2009 SRT8 Challenger 6 Speed
Offline Dusty1
  • Revived
« Reply #5 on: March 21, 2012 - 10:51:53 PM »
Thanks guys!
Garys 1972 BS
