Author Topic: Brake Warning light  (Read 7364 times)
Offline wiging19
Re: Brake Warning light
« Reply #30 on: April 15, 2012 - 06:32:36 PM »
Sounds like the right decision both from a safety and monetary point of view.  After all the work and money you've put into the car the last thing you want is an accident caused by brakes failing on you.   :bigsmile:
Offline Jamiez
  • Retro
« Reply #31 on: April 16, 2012 - 05:46:46 PM »
Well the side that was leaking the boot came right off when I went to remove the push rod.  I'm no expert but I'm guessing the wheel cylinder isn't supposed to look like this:
Offline highberg
« Reply #32 on: April 16, 2012 - 07:50:00 PM »
The proportioning valve can be fully stuck in one direction and all brakes will still work fine. If all the brakes are ok, you will need to bleed it out to move the proportioning valve. Bleed the back first, check your light, bleed the front, etc.
Classic Restorations
1973 Cuda 496 Stroker NOS
1971 440+6 4 Speed Roadrunner
1961 Shortbox Fleetside D100
1970 Dodge Dude 383 Auto
2009 SRT8 Challenger 6 Speed
Offline Jamiez
  • Retro
« Reply #33 on: April 28, 2012 - 08:09:45 PM »
Well I've swapped the wheel cylinders, and replaced all the brake lines.  I just need to bench bleed the master before I hook it up and bleed the rest of the system.
I soaked and cleaned the prop valve.  At the very least it looks better :)
Before:
After:
Offline wiging19
« Reply #34 on: April 29, 2012 - 01:03:28 AM »
Looks nice. :jumping:
Offline Jamiez
  • Retro
« Reply #35 on: May 03, 2012 - 09:08:20 PM »
It's all in and bled.  There were one or two connections that I forgot to tighten (oops!) but now it all seems good.  The warning light is working as expected.  I hope to get the wheels back on it this weekend and take it for a short shake out drive if the weather cooperates.
 :woo:
