A/C heater Vacuum lines-> help needed
Author Topic: A/C heater Vacuum lines-> help needed  (Read 8607 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
« on: March 21, 2012 - 08:29:42 PM »
Re: Vac lines for Ac/heater control
« Reply #1 on: June 29, 2011 - 07:33:19 PM »
Quote
the line enters the engine bay through a hole in the firewall under the heater hose connection , I think the other end connects to the switch plug
Chryco
I have the heater/AC vacuum lines hooked up, and have no visual reference for how /what the lines draw vacuum from.
anyone have a pic of what it's supposed to look like/connect to?
Thanks in advance!
Dan
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: A/C heater Vacuum lines-> help needed
« Reply #1 on: March 22, 2012 - 06:14:51 AM »
Dan
The line that goes through the hol in the firewall is routed to the vacuume push button switch on the dash.
The other end is connected to a vacuumed port on the intake manifold on the motor.
From the switch the lines go back to all the vacuume pods.
But I think you know that part, are you wanting to know what lines go to what port?
Go Fast & Have Fun...
Offline DMZ73
« Reply #2 on: March 22, 2012 - 10:39:33 PM »
Thanks Scott, I just don't know wherethe vacuum hose goes out the firewall.
I spoke to steve today, and he mentioned I should have a bung off the intake manifold that comes off the intake manifold..
the key here being should...because I don't..
Just tryin to get it right..
Dan
Offline swede-cuda
« Reply #3 on: March 24, 2012 - 12:28:54 PM »
 :jumping: hej.the small vacuum hose enters the engine bay through a rubber grommet(if the grommet have 2 holes then also the cable for the water valve goes through it) ,the grommet mounts to the firewall with 3 screws,so look at your firewall where chryco said,for a bigger hole with 3 screw holes around it.  :bigshades: . ok,then on my 70 383 4sp the tiny hose connects at a tee behind the carb,where 1 hose goes to the pod stuff on the dual snorkel air cleaner,and the ac tiny whiny hose connects at the passengerside rear of the carb base plate.its just a pipe in the base plate,just like a distributor vacuum connection in the base plate.i guess you can connect it anywhere as long as it gets full vacuum.if you dont have a chrysler/correct carb then maybe drill a hole in a spacer plate an put a fitting in it for the vacuum hose.  :dunno:
Offline Katfish
  • 70 Challenger
« Reply #4 on: March 24, 2012 - 12:31:20 PM »
Passenger side near bottom
Offline DMZ73
« Reply #5 on: March 26, 2012 - 06:56:59 AM »
Thanks Katfish!
The firewall picture is extremely informative.
I do have a few other dumb questions.
1. What diameter tubing comes out of the firewall to meet the vacuum port?
(the diameter tube coming off the vacuum "pots" is 1/4". Is this correct?
What is the overall length of the vacuum hose?
2. What does the HVAC vacuum tube grommet look like?
3.I have, or am supposed to have a manual footpump washer system.
I see a footpump hole in the firewall. What does a manual footpump system look like?
4.What does the footpump grommet look like?
Thanks again!
Dan Zimmermann
Offline swede-cuda
« Reply #6 on: March 27, 2012 - 02:55:46 PM »
good luck :picture:
Offline FY1Cuda
« Reply #7 on: March 27, 2012 - 06:20:16 PM »
You can get the vacuum for the AC from the manifold if the tap for the power brakes (I'm assuming you have power brakes if you have AC) has a little nipple like show in the first picture.  You can also tap off of the power brake booster if you have a plastic plug with the small nipple like in the second picture (our's is capped off).  The following link from Moparts shows you the grommet and explains a few things:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4593103&an=0&page=564
Offline DMZ73
« Reply #8 on: March 28, 2012 - 12:27:19 PM »
Thanks !
Nice link, and very informative thread. I guess I missed that lil guy in my HVAC resto.
So here's what I have so far:
This is the grommet for the HVAC Vacuum tube.
It clearly shows the proper vacuum hose scale, however, the nipple port on the Power Brake Booster is 1/4", and the nipple port ont the vacuum pot is also 1/4"
Here is the vacuum pot setup "original" to my car
Right now, I have my Heater cable coming through this foot pump hole with a grommet of unknown origin.
I am also running my Oil pressure line through the same grommet
I see an option to run a vacuum nipple here:
And through the firewall in the "correct" location
If you look at the pics of my engine bay when I recieved the car, you will notice that the vacuum line was in fact on the Power Brake Booster.
http://www.pbase.com/dmz73/image/65717750
It really doesn't matter where I hook up to get vacuum, however, I would like to know if it is OK to run the 1/4" vacuum line, or if I need to reduce it.
I also found a few nice reference shots of the vacuum tube routing.
http://s617.photobucket.com/albums/tt251/dmz73/?action=view&current=b3b28ffb.jpg
http://s617.photobucket.com/albums/tt251/dmz73/?action=view&current=a669e953.jpg
Here's my Engine bay Before:
http://www.pbase.com/dmz73/image/65717756
Here is my Engine Bay today:
Another dumb question.
I have a new engine bay harness. What does the "blue" Compressor wire hook up to?
Does it hook up to the brown wire?
Best,
Dan
« Last Edit: March 28, 2012 - 12:29:34 PM by DMZ73 »
