Author Topic: ITS ALIVE!!! but it has a stumble, help!  (Read 3717 times)
Offline torredcuda
  • Epping NH joined 11/23/03
Re: ITS ALIVE!!! but it has a stumble, help!
« Reply #15 on: March 29, 2012 - 05:18:42 PM »
If the mixture screws are having no effect than you are past that point and your throttle blades are too far open.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 72cudamaan
« Reply #16 on: March 29, 2012 - 05:39:21 PM »
I don't understand why there are holes in the butterflies.
That does the same thing as turning up the idle speed screw doesn't it.
I mean besides taking the carb out of the idle circuit, is it really a help? or
os it masking other problems. It doesn't seem right that this would be necessary on a stock to slightly mild build.   :dunno:
« Last Edit: March 29, 2012 - 05:46:24 PM by 72cudamaan »
If I cant fix it, it's broke
Andy  (phukker whither)
Offline The4ork
« Reply #17 on: March 29, 2012 - 07:20:57 PM »
It allows more air through the carb to keep running without having to open the throttle plates, thus I am able to keep perfect squares in my transition slots
Offline LAA66
« Reply #18 on: March 29, 2012 - 10:03:31 PM »
 Swap the carb out with a friends, (similar size) if it runs right there's the problem. If not maybe other issues with the engine. I had a broken valve spring cause a stumble on a 340. Could have tuned all day with no avail. Not saying that's the problem but a carb swap is quick and easy. Good luck. :)
Offline MOPAR FANATIC
« Reply #19 on: April 04, 2012 - 06:19:02 PM »
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
Offline The4ork
« Reply #20 on: April 04, 2012 - 10:17:16 PM »
that just sounds way more hassle than its worth, plus everyone i know has big blocks.
i can get 99% of the stuble to go away if i make my idle mixture waaaaaaaaaaaaayyyy rich, im talking like a chugging 10:1 or less air fuel mixture but then its stupid rich cruising at part throttle at a constant speed.... grrr! i reek of gas now and my nose burns!
