Author Topic: How to wire up a mopar performance wiring harness???  (Read 2750 times)
Offline cudamr440
  • I'm a llama!
« on: February 03, 2005 - 03:16:21 PM »
I just got a electronic convertion kit from summit part #DCC-3690152 . This harness will convert from points to electronic ignition..
How and what color wires hooks up to what???????????????
No directions in the package >:(
« Last Edit: February 03, 2005 - 03:32:57 PM by cudamr440 »
Re: How to wire up a mopar performance wiring harness???
« Reply #1 on: February 03, 2005 - 04:05:05 PM »
If you are asking about the connector that comes out of the electronic control module, I might be able to help you. I'll look this weekend. Someone did that conversion to my 1970 440.
Offline cudamr440
  • I'm a llama!
« Reply #2 on: February 03, 2005 - 04:23:19 PM »
The connector that comes out of the electronic control module.  Wire colors are: green with a red stripe, gray with a yellow stripe, black with a yellow stripe(coil I think).
Any info will help
Thanks
« Reply #3 on: February 03, 2005 - 11:18:43 PM »
Black with yellow is coil - as you assumed ,
 green / red is not used
 Grey [really blue] with yellow trace is connected to 12V switched power at the ballast resister & the wire is dark blue , you can solder onto it or scotch lock it
Offline cudamr440
  • I'm a llama!
« Reply #4 on: February 04, 2005 - 12:26:43 PM »
Thanks
This info will help alot! :thumbs:
