Author Topic: 1970 Cuda resurrection  (Read 119199 times)
Offline HP_Cuda
  • Mopar or No Car!
Re: 1970 Cuda resurrection
« Reply #195 on: November 23, 2013 - 04:18:23 PM »
Yeah I'll check them out, and worse case I can swap them out.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #196 on: November 23, 2013 - 04:31:37 PM »
Got the front markers on no problem but had an issue with the rears.
Looks like some modification is in order to get the lights to mount.
Ughhhh
Offline HP_Cuda
  • Mopar or No Car!
« Reply #197 on: November 30, 2013 - 12:11:18 PM »
Thought I'd test fit the rear seat and make more room in my house!!!
Offline ragtopdodge
« Reply #198 on: November 30, 2013 - 03:34:26 PM »
Curious on the use of '72-'74 seat pattern?
 :clueless:
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline ShelbyDogg
« Reply #199 on: November 30, 2013 - 07:57:32 PM »
It's the little things that will give it away in the end, if you don't make sure everything is correct for the year you are building. Unless you don't care about anyone knowing it was a later model?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #200 on: December 01, 2013 - 02:33:52 AM »
When I purchased the car the car did not have 70 bucket seats, it had the 72-74 style so....
It does not bother me since this car is not a numbers matching type of car, this car is pure fun.
The other *Cuda* I bought is numbers matching and will have everything put back to stock. Actually my roadlamps for it should be in any day now....
 :clueless:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #201 on: December 02, 2013 - 06:38:25 PM »
Hot Dang for Classic Industries Black Friday holdover as I just bought glass for my doors which was the last major component I needed!!!
 :bananasmi :droolingbounce: :burnout: :woohoo: :2thumbs:
Offline Ricketts
« Reply #202 on: December 02, 2013 - 08:35:44 PM »
Wow, car is coming along awesome!! Keep up the good work!
Offline BFM_Cuda
« Reply #203 on: December 02, 2013 - 11:35:56 PM »
Really looking nice!
What was the issue with the rear marker light?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #204 on: December 03, 2013 - 01:47:00 AM »
The housings had to be slightly modified to make them fit...that's all.
Fit the rear seats
Cut the carpet, move it around
Mount the Dash
Wire it up
Get the driveshaft made
Put the Bucket seats in and fire it up!!!
Heck I wish is was just wire and fire but it's getting close.
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« Reply #205 on: December 03, 2013 - 10:57:05 AM »
Are you going to assemble the whole dash before installation? I found that it was pretty easy to install all the gauges/wiring/duct etc on the bench and then install it all in one swell foop. The only gotchas I'd watch for is to stuff a rag into the defrost ducts so you don't have to R&R the dash (don't ask). I also had to remove my dash light dimmer switch after installation. It worked when it was originally removed ~15yr ago so I assumed it still did. The copper was all corroded and needed to be cleaned so I didn't have instrument cluster lights at all.
Other than that, it was much easier to assemble since I could get to everything easily on the bench without having to lay contorted upside down in the car.
$.02
Offline anlauto
« Reply #206 on: December 03, 2013 - 12:38:01 PM »
 :iagree: It's the ONLY way to do it !
Offline HP_Cuda
  • Mopar or No Car!
« Reply #207 on: December 03, 2013 - 01:56:44 PM »
Yep as you can see here its all going back in as one unit:
http://www.cuda-challenger.com/cc/index.php?topic=83942.msg883109#msg883109
And I went through the gauges and cleaned them up and tested them as well. It's awesome when you have plenty of 12.3V lipo batteries to test everything with, even the windshield wipers!!!  :2thumbs:
So I'm guessing that you crushed the defrost ducts, otherwise I don't understand what you meant.
Offline peterro
    • The Pistonhead
« Reply #208 on: December 03, 2013 - 02:14:44 PM »
Nope. I dropped one of the dash mounting nuts down the the vent. I thought about leaving it and finding another nub but figured it would rattle and mock me when I was driving so I had to R&R.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #209 on: December 03, 2013 - 04:06:41 PM »
Gotcha now, kinda like stuffing the intake with a rag while changing out carbs - don't want any stray nuts to fall down there!
 :bricks1:
