Author Topic: 1970 Cuda resurrection  (Read 119148 times)
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: 1970 Cuda resurrection
« Reply #405 on: August 01, 2016 - 05:10:15 PM »
I have extra gauges and should have a good fuel gauge if you need.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline HP_Cuda
  • Mopar or No Car!
« Reply #406 on: August 01, 2016 - 06:20:21 PM »
Thanks Dave!!!
Looks like I have great news. I got another fuel gauge to work and I may swap this out for another one tomorrow as this one is ok but the needle is faded and has some imperfections.
I'm going to do a writeup on gauge testing as I guess I have learned all I can recently.
 :smilielol:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #407 on: August 06, 2016 - 02:16:28 PM »
Happy Days!!! Before and after pics with added fuel.  :2thumbs:
Next I'll post up a vid of her idling - sounds nice.
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #408 on: August 06, 2016 - 02:18:10 PM »
 :woohoo:  good progress buddy!
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline js29no
« Reply #409 on: August 06, 2016 - 02:49:10 PM »
It's nice when that happens!!! :bigsmile:
Offline CudamanTom
« Reply #410 on: August 06, 2016 - 07:56:26 PM »
 :cooldancing:  :ylsuper:
And can't wait to see/hear her idle.   :2thumbs:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #411 on: August 06, 2016 - 09:22:29 PM »
Dang, nip one problem get another.
Now I have to adjust the power steering valve body as it almost ripped the steering wheel out of my hand by whipping right.
Ughhhhh
Offline HP_Cuda
  • Mopar or No Car!
« Reply #412 on: August 06, 2016 - 11:26:56 PM »
So let me get this straight. If you loosen the steering valve body screws and tap on the end plug I should be able to stop the automagic right turn when I start the Cuda?
So far I have backed off the bolts and tapped on the end plug and I still get a massive right turn on starting the motor. I have to shut her off quick as I don't want it to go to the stops and pop an o-ring. As well, I have the front wheels off the ground before I start the motor each time.
Here is the part I am not getting. How would hitting an end cap or the screws for the valve body do anything since they have threads? How are you going to move a valve one way or the other?
Am I missing something?
« Last Edit: August 06, 2016 - 11:50:55 PM by HP_Cuda »
Offline rUNCHARGER
« Reply #413 on: August 06, 2016 - 11:56:37 PM »
There;s a toggle that sticks up into that casting. Loosen the bolts off and move the casting towards the firewall this time and then try it. It will take a few tries,
Offline HP_Cuda
  • Mopar or No Car!
« Reply #414 on: August 07, 2016 - 12:50:27 PM »
Thanks Runcharger - I finally figured it out after I kept looking at a pic which pointed at the control valve body screws.
Basically do not loosen the control valve body screws (you only tap on them), you need to loosen the steering valve body screws. Then tap on the endcap to push it down(remove right turn) or the control valve body screws to move it up(remove left turn).
Hope this helps others as I was confused trying to loosen the wrong screws and got nowhere - doh!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #415 on: August 07, 2016 - 03:28:35 PM »
Well I can say "SUCCESS!!!" after burning the hell out of my thumb on the headers I got the power steering to behave like it should and it moves smooth as silk now. A bit of tapping and restarting the Cuda and that was it!
I need to wait till she cools down so I can get near that plug wire to tighten the last bolt down to 16 ft lbs.
Meanwhile I took a vid of her idling - enjoy!
https://youtu.be/l15inSa8cQk
Offline rUNCHARGER
« Reply #416 on: August 07, 2016 - 04:55:18 PM »
Excellent! Car is looking nice.
Sheldon
Offline CudamanTom
« Reply #417 on: August 08, 2016 - 07:17:14 AM »
Hell yes!!! That sounds super nice!!!  :2thumbs: :ylsuper: :cheers:
I can smell that beautiful classic car exhaust now. :)  :burnout:
« Reply #418 on: August 08, 2016 - 07:27:28 AM »
Sounding great HP!
Won't be long now  :working:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #419 on: August 08, 2016 - 08:33:40 AM »
She sounds real nice!  What exhaust and mufflers are you running?
