Author Topic: 1970 Cuda resurrection  (Read 119151 times)
Offline HP_Cuda
  • Mopar or No Car!
Re: 1970 Cuda resurrection
« Reply #420 on: August 08, 2016 - 12:07:02 PM »
2.5" Exhaust to the back with Dynomax VT mufflers.
Offline Plum6Pak
  • Plum6Pak
« Reply #421 on: August 10, 2016 - 01:12:23 PM »
Sweet! Sounds like a MOPAR should!  :burnout:
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #422 on: August 10, 2016 - 02:49:19 PM »
Sounds great Bryan!!
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline AU6pack
« Reply #423 on: August 11, 2016 - 01:39:25 AM »
Sounds awesome. Great build  :ylsuper:
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline HP_Cuda
  • Mopar or No Car!
« Reply #424 on: August 11, 2016 - 04:46:11 PM »
Well she moved under her own power ran her up and down the driveway, the drive train works great although I thought I might have some issues with the shifter but nothing.
Looks like I may have to add a vacuum canister as I'm around 8" of vacuum right now.
Offline CudamanTom
« Reply #425 on: August 11, 2016 - 05:21:51 PM »
Great to hear Bryan.  :2thumbs:
Just curious, did you raise the rear wheels off the ground (on jacks) and and let the engine/tranny run the drive train? I did this to listen for any odd sounds before putting her to higher speeds.
Basically, I just had it in first gear and the engine at idle. I didn't want to spin the tires too fast while on jacks.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #426 on: August 11, 2016 - 05:24:14 PM »
Good idea Tom, may give that a try tonite.
I was thinking of just putting around the neighborhood and seeing what would shake loose.
So far nothing major. I'll keep my fingers crossed!!!  :2thumbs:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #427 on: August 14, 2016 - 10:46:58 PM »
Well great news today finally I figured out what the heck happened with my vacuum. Ughh one problem then the next.
The story begins with redoing the lash which my machinist was paid to do, doh! Check and done. The car now has a valvetrain that sounds like a Mopar should. Once we put everything back together I lost my vacuum - it went down to 7.5 and was a bit sporadic. I was perplexed, did setting the lash correctly have anything to do with that I thought? Well long story short, after trying to find any sort of vacuum leak (none found), or find some sort of spark issue (all plug wires set and in right order). I finally figured out that maybe I bumped my distributor when I put the tall valve covers back on. Yep that was it. The timing got retarded and I lost my vacuum. I set the timing back and wow the throttle is snappy as ever. I put her at 16 degrees initial and I get 20 from the distributor so this should be a real rocket ride.
I'm so freakin happy as I thought I might have to tear the motor down or at the very least break down the valve train again.
 :bananasmi :clapping: :bananasmi
B
« Reply #428 on: August 14, 2016 - 10:50:34 PM »
 :bananasmi
« Reply #429 on: August 14, 2016 - 11:33:22 PM »
B
 :clapping:  :2thumbs: :2thumbs:
Time to go for a cruise
Offline CudamanTom
« Reply #430 on: August 15, 2016 - 07:08:27 AM »
I love a happy ending.  :2thumbs: :bananasmi :bigsmile:
« Reply #431 on: August 19, 2016 - 10:41:21 PM »
Have you been able to straighten out the DMV issue yet?
Offline dutch
« Reply #432 on: August 20, 2016 - 04:23:28 AM »
oh boy.... do I miss that sound   ::)
she turned out really really good Bryan  :drool:
goed gedaan jongen!  :clapping:
*** Bart ***
Offline HP_Cuda
  • Mopar or No Car!
« Reply #433 on: August 20, 2016 - 12:47:06 PM »
If you ever come over dutch, I'll take you for a ride of a lifetime!!!  :burnout:
Btw, I think I'll take her around the neighborhood to do a shakedown - just gotta check the u-joints and the toe-in.
Bedankt mijn Vriend  :netherlands:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #434 on: August 20, 2016 - 12:47:38 PM »
I hope to get to the DMV this next week Mike!!!
